Front u joint ??
Old Apr 11, 2005 | 08:31 PM
theshocker's Avatar
theshocker
Default Front u joint ??
I am pretty sure my front right u-joint is bad. I kept hearing a rattling noise coming from the front end. I took my wheel off today and the u-joint was defenetly bad. I could move back and forth, and when I spun the rotor in made the noise I was hearing. I did a seach here, but all I could find were people asking about the noise and others saying that bad u-joints were probably the problem. Has any one changed there u-joints? It doesn't seem to difficult if you have the right tools. If any one has any info or links that would be great!
Old Apr 11, 2005 | 08:41 PM
crusher135's Avatar
crusher135
Default RE: Front u joint ??
this is pretty close to the front axle we have in our trucks it tells u how to do it but u dont have to take off the axel nut u only have to if u want to get to the wheel bearing and sometimes when u try topull off the asembily that is where the wheel nut is its rlly hard but give it a shot http://www.stu-offroad.com/axle/d30/axle-1.htm
Old Apr 11, 2005 | 08:54 PM
theshocker's Avatar
theshocker
Thanks for that tid bit man. Now I have to decide if and when I want to do it. Wonder how much a shop would charge?[sm=yikesomg.gif]
Old Apr 11, 2005 | 09:45 PM
crusher135's Avatar
crusher135
in british columbia langley they charge 110$ for that u-joint to be done
