Rusty chrome bumper on a 97
Old Nov 28, 2009 | 04:55 PM
tomwom's Avatar
tomwom
Originally Posted by rwilhelms
You can get a brand new rear chrome bumper from ebay motor for about $400. But I know that if I ever need to replace my rear bumper that I'd get a roll pan. I like the way they look on are trucks and are a hell of alot cheaper than an oem replacement. Im just not sure if you can use a hitch with them
Ok, you got me, what's a "roll pan"?
Old Nov 28, 2009 | 04:59 PM
tomwom's Avatar
tomwom
Never mind, I just googled it. Looks like a good alternative, thanks!
Old Nov 28, 2009 | 05:25 PM
Augiedoggy's Avatar
Augiedoggy
How bad is the rust on the chrome? If its just surface rust try cleaning it first. When I detailed cars at the chrysler dealership I always used wax or chrome polish with a light grit steel wool. Then whipe off whats left after scrubbing. You can put a little elbow grease into it but not to much or you'll take the chrome right off (oops found that out the hard way) This is the way I clean anything thats chrome and only had a problem once
problem with that method is when you clean it with steel wool your usually creating thousands of tiny scratches that give the rust an even easier time reforming.... if the chrome is so bad that it cant be cleaned with just polish and non abrasive to chrome scrubby then steel wool can be used but should be sealed afterward with clearcoat to prevent reforming.
Old Nov 28, 2009 | 05:27 PM
Augiedoggy's Avatar
Augiedoggy
I've got the heavy duty road warrior rear bumper myself...came on the truck when I bought it...
Old Nov 28, 2009 | 10:26 PM
rwilhelms's Avatar
rwilhelms
I never realized that about cleaning with steal wool. Also as long as I brought up roll pans can use them with a hitch installed on your truck? Also do they just mount with the stock bumper mounts
Old Nov 28, 2009 | 11:31 PM
rideordie's Avatar
rideordie
Looking at a couple, they say that you can get them with or without an access point for a hitch. I don't know if they mount with the stock mounts, but I'd imagine they do.
However, I don't think they look good.
Old Nov 29, 2009 | 01:12 AM
redheadhunter21's Avatar
redheadhunter21
Depends on the hitch, if you have a drop down hitch some will clear the roll pan and be just below it, or some people will make it so that you can flip up the license plate, my friend has an SS/T and he just takes off his plate and sticks it in his window and the reciever is right there and keeps it from being too low
Old Nov 29, 2009 | 01:15 AM
rideordie's Avatar
rideordie
After thinking about it today, it could look cool to buy a used one somewhere and paint it either black or green..There was a thread on here about it.
The only thing is if I wanted it to be green, it'd need to match..Anybody know an easy way to find a matching color spray paint?
Old Nov 29, 2009 | 01:25 AM
Laramie1997's Avatar
Laramie1997
Hercules.
Old Nov 29, 2009 | 06:39 AM
tomwom's Avatar
tomwom
Originally Posted by Laramie1997
Hercules.
Now that's a bumper!
BTW, you need tires!
