Lt. Looney
Old Nov 29, 2009 | 12:47 PM
CappinHoff's Avatar
CappinHoff
Default Lt. Looney
This is my first major project I'm going to be doing. My dad passed away and I got his truck. It's a 2000 Dodge Ram 1500 Laramie 4x4 w/5.9L V8. So in memory of him the project will be "Lt. Looney" In the coming days/months/years I will be working on it. I'm not gonna do anything crazy.
Projects, no specific order.
  • new paint.
  • new dash.
  • clean up rims, and wrap them in new rubber.
  • convert the emblems to the new style on the 2005 and up models.
  • exaust system.
  • rhino lined bed, frame, underbody.
  • euro style headlights and tailights. HID's in from and LED's in the back.
  • winch
  • nerf bars
  • new plugs/wires/cap/coil
  • upgrade chip
These are just a few of the things I'm gonna change. I'll be starting with a tune up and a new K&N air cleaner kit, E3 sparkplug/wire upgrade. Switch from regular oil to mobil 1 synthetic.
To see pics of the build go Lt. Looney
Any comments or advice welcome.
Will keep updated
Old Nov 29, 2009 | 01:16 PM
Sheriff420's Avatar
Sheriff420
you're missing a couple.
plenum gasket with aluminum belly pan. then upstream o2 sensor and high flow cat.
timing chain/water pump.
maybe hubs/u joints on the front axle.
Old Nov 29, 2009 | 02:57 PM
CappinHoff's Avatar
CappinHoff
Dang it I knew I forgot some. I definitely want to do the plenum gasket. The high flow cat is going with the exhaust. Timing chain/water pump for sure. And the hubs and u joints for sure. As for the aluminum belly pan, not to sure what that is. Enlighten me.
Old Nov 29, 2009 | 03:03 PM
Augiedoggy's Avatar
Augiedoggy
Aluminum belly pan lit (hughes sells them) solves the problem of the new plenum gasket failing because the steel pan expanded and contracted at a different rate than the rest of the manifold(cast aluminum) causing the seal to break and blow out the gasket...
Old Nov 29, 2009 | 03:09 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
No hookers and blow??
Old Nov 29, 2009 | 03:19 PM
CappinHoff's Avatar
CappinHoff
I'm gonna do headers. I'm not looking to make this truck a racer. Just somethings to make it run a lot better and to keep it longer. Also to freshen it up a bit.
Old Nov 29, 2009 | 03:22 PM
Sheriff420's Avatar
Sheriff420
shorty headers do make it run better. mine held highway speed easier after i put a set of shorties on.
Old Nov 29, 2009 | 04:34 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
My comment went R-I-G-H-T over your head. Think about it
Old Nov 29, 2009 | 04:41 PM
CappinHoff's Avatar
CappinHoff
My goal is to make it look better and make it run better in the end. I thought about building up a 408, but nah I like the 360. I just want to help it breath easier in both direction and run nicer.
I got what you where saying.
Old Nov 29, 2009 | 05:08 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I got what you were saying.
