The best 14x3 for the money?
Yes, you need the bent rod because the threaded hole in the throttle body is off set. It's not centered.
I had that on my '98 Dakota. Do you have a bunch of dirt under the filter when you take it off to clean it? Mine seemed like it let alot of stuff go through.
ya i can feel a diff atfer about 2500rpms up pull a little harder
well i felt a little differnce all the way around but the best part was 2500+
after awhile i thought i loss buttom end so i put the stock back on and could feel the diff loss of power 2500+ and down end was about the same,,, but i also have a 50mm tb
for 30 bucks i dont think you can go wrong,,, i looked at it this way for 30bucks i can take my girlfriend to dinner or take her 4 ride in the truck with the new air cleaner((( my gf smiled so big when i got into that pedal)
or just save a dollar a day and you can get one
but dont think that 4 for 30bucks or going to have a race truck
plus it looks cool as hell!!!!!!!!!!
hope this helps
hope this helps
my only thing is that i think it would be sucking all the hot air from under the hood into the intake since its sitting right there on top. i just dont think it would work as good sucking in all that hot air
