The best 14x3 for the money?
Old Nov 30, 2009 | 05:43 PM
Mudshack's Avatar
Mudshack
Default The best 14x3 for the money?
Which is it? And where do you get it? Local places, or online? How often do you clean/replace them?
Old Nov 30, 2009 | 05:51 PM
Twisted Metal's Avatar
Twisted Metal
Umm wow, D: All of the above? All parts stores and online parts sources sell 14x3's. My RAC is an AEM DryFlow. I clean it at every service on my truck. The AEM flows alot of air, and since its a dry filter you don't have to oil it. Just wash it and let dry, and reinstall. I have a regular paper filter that came with my Edelbrock that I use while my AEM is out and drying.
Old Nov 30, 2009 | 05:52 PM
Sheriff420's Avatar
Sheriff420
mr. gasket 14x3 30ish$ no spacer needed to clear throttle cables or sensor wires.
k&n 14x3 filter 50ish$ never needs replacing, clean whenever its dirty (about every 30-50k miles.
i got mine at advance.
Old Nov 30, 2009 | 06:01 PM
Mudshack's Avatar
Mudshack
Maybe someone can add the 14x3 filter to the DIY or FAQ section.
Also, Somewhere I was reading you have to bend and cut something.
Old Nov 30, 2009 | 06:02 PM
quackaddict's Avatar
quackaddict
I want your setup if you don't mind, do you have part numbers for the filter or just say I want an Edelbrock 14x3 and the AEM filter that will fit it?
Old Nov 30, 2009 | 06:04 PM
Mudshack's Avatar
Mudshack
Twisted Metal, your engine is sexy!
How much was that black Edlebrock and AEM filter?
Old Nov 30, 2009 | 06:13 PM
Twisted Metal
Thank Mud, there is a DIY for doing the RAC conversion. You have to bend an s bolt( made from 5/16" diameter all thread). The Edelbrock was 30, the AEM was 50. Both available from Summit
https://dodgeforum.com/m_950007/tm.htm- 14x3 RAC DIY
Quack, I sent you a PM
Old Nov 30, 2009 | 06:17 PM
Sheriff420's Avatar
Sheriff420
its actually 1/4-20 threaded rod
Old Nov 30, 2009 | 06:18 PM
silverbullet-dodgeram's Avatar
same here im thinking bout doing this for my winter driving (my ram air make my engine run at 135 degrees if its colder than 45 out side) i would like some heat on those days
Old Nov 30, 2009 | 09:05 PM
meanwhitemopar's Avatar
meanwhitemopar
anyone got anything on the holley 14x3?
and do you have to do that bent rod thing to do the 14X3?
