Header coatings? JET-HOT!
Old Dec 3, 2009 | 06:25 AM
RM_Indy's Avatar
RM_Indy
Originally Posted by BlueBeast2
true but when you only pay 150 for them in the first place. I figured its kinda crazy to spend that much. Not sure what the pre coated ones sell for. I decided to give the Eastwood high temp header paint a try. I figure why not give it a shot. Maybe it will hold up and I can save some people money. **** for 30 bucks a can it better hold up for a while
Curious how the Eastwoods holds up. I buy all my powder coat stuff from them. Just got an airbrush from there also. Never tried their hi heat paint but any of the others Ive tried over the years was all crap and burnt off in no time. My case is extreme, between hp level Im shooting for and the fact I have 5lbs of block cement in my water passages, I felt I needed more thermal protection than just alum heads & the bigger rad.
Old Dec 3, 2009 | 10:03 AM
Twisted Metal's Avatar
Twisted Metal
Indy, I have a customer of mine that used it on a street rod project we helped him with. I'll ask him. I know he was using it for the block,heads and headers.
Old Dec 3, 2009 | 11:39 AM
1fast2liter's Avatar
1fast2liter
that engine gives me a stiffy
Old Dec 3, 2009 | 11:42 AM
1fast2liter
rmindy dosnt that block cement in the water passages impede on your cooling ability?
Old Dec 3, 2009 | 02:01 PM
RM_Indy's Avatar
RM_Indy
Wanted some block cement to strengthen the bottom end more than just what the mains girdle will add. The cement is more in the bottom of the block & not the actual passages themselves but yes, it does impede cooling, hence the reason I was willing to spend extra on quality thermal coatings.
As far as the stiffy goes, yeah me too. The wife thought I was going to sleep in my garage cause I was so excited after doing the mock up to make sure everything still fit together lmao
Twisted - I was just curious about the Eastwood hi heat, its not like I will not be using it cause I have already got everything coated thats heat related with specialty powder coat.
Ram_Me - You just love showing off that beautiful engine of yours..
Yes I do
Daily - thanks
Old Dec 3, 2009 | 02:29 PM
Ram_Me's Avatar
Ram_Me
Originally Posted by RM_Indy
Yes I do
Daily - thanks
You're welcome! You can keep showing it off just as much as you like, I definitely do not mind!
Old Dec 3, 2009 | 03:24 PM
RM_Indy's Avatar
RM_Indy
Rocks360, were you planning on getting the new parts shipped directly to Jet Hot to be coated & then Japan or sent to home in the US?
One thing about coatings, be sure you have the right parts before coating. Found that out back in 98 when I got my valve covers, chrome diff cover & a dips stick tube coated. Dropped off all the parts as soon as I got them, didnt open the parts bags duhh, Turned out I got a 318 dipstick tube coated. No returning parts once coated
Old May 5, 2010 | 03:15 PM
Mr-Sleeper-34's Avatar
Mr-Sleeper-34
I ordered my Pacesetter LT hdrs painted cause I wasnt sure if they ceramic coated the inside. Was going to go with Jet Hot but shipping on all my parts (wanted other stuff done) was going to cost way too much. I went to a place up here called Fireball coatings (Ont/Cda). http://www.fireballcoatings.com/inde...id=4&Itemid=12
They blasted, added flanges, cleaned up my weld job on the 2nd o2 bung & coated ceramic inside & outside (30% under hood temps claimed) as well as got their XMC 3 stage coating on the inside also. Its suppose to further reduce underhood temps so they're 70% lower with the ceramic. My ported M1/4BBL has special heat reflecting coating on the under side & their heatsink thermal (disperses heat faster) on the top of it. My blower pistons have ceramic coated tops & moly coating on the skirts.
edit - Oh, & I detailed the M1 with ceramic blue & silver paint myself
^That engine is full of win. Any updates on that thing? Is it in the truck already?
