please help. my 1500 ram will start but won't go anywhere
Old Dec 3, 2009 | 04:15 PM
charbel's Avatar
charbel
oh ye. it was the cat. i took the bolts of the exaust that connect to the pipe. 2 of them broke the other 2 came off.
and i pushed both pipes down a little. and voula.. runs like a dream. aside that is loud as hell. we don't do inspection here in MI so i might just run 2 pipes unless i can find a cheap cat to buy.
thanks guys for the help
Old Dec 3, 2009 | 05:21 PM
Cheat's Avatar
Cheat
Or you could goto autozone and get some flexible exhaust tubing and just put that there?
Old Dec 3, 2009 | 05:59 PM
Sheriff420's Avatar
Sheriff420
that melted piece is the evap purge solenoid.
i kinda figured it was the cat. if yours is one pipe in/one pipe out then you can get a universal magnaflow at summitracing.com
Old Dec 3, 2009 | 06:37 PM
charbel's Avatar
charbel
it is 2 pipe in and one pipe out. maybe i can cut the side of the cat and empty it then weld it.
i found one out of 2007 1500 ram for less then $100 . going to look at it. i am prety good in doing work like that. just finding the problem is always tricky
Old Dec 3, 2009 | 07:01 PM
seabass202's Avatar
seabass202
If you take your time, you should be able to break up the internals (honeycomb) of the clogged cat with a hammer and a 3/8 extension. basically hollow it out and then bolt it back up. will look stock and you don't need to buy anything.
Old Dec 3, 2009 | 07:11 PM
Augiedoggy's Avatar
Augiedoggy
I wonder if cooking it in a fire like they do to plugged up 2 cycle mufflers on golf carts and atv's/dirt bikes when they plug with sooty oil would clean them out?
Old Dec 3, 2009 | 07:46 PM
Sheriff420's Avatar
Sheriff420
if you knock it all out then you may want to think about a glass pack to cut down on the race car sound.
Old Dec 3, 2009 | 08:51 PM
98 Ram "Hybrid"'s Avatar
98 Ram "Hybrid"
Clean out the cat and put on one of these....
http://www.hotlicksexhaust.com/
Old Dec 4, 2009 | 12:04 AM
Sheriff420's Avatar
Sheriff420
^awesome for showing it off at a car show but if you were to light the pipes on a state road then you'd be in hot water with any cops that might see it.
Old Dec 4, 2009 | 02:04 AM
charbel's Avatar
charbel
lol that is funny.
