reverse cut gears???
Old Dec 4, 2009 | 01:58 PM
meanwhitemopar's Avatar
meanwhitemopar
Default reverse cut gears???
ok as many know, i have the ram 1500 with the dana 60s( out fo a 99 2500), i need to regear... but i have to chnge carriers.. unlesss i do thick gears.. in which case i can use the 4.10 and down carrier... my question to you guys is can i use a reverse cut gear in my dana 60's... or does anone know where i can get a set of thick gear 5.13's reg cut...
nd maybe whats the differance? i have heard they are for hgih pinion or low pinion as to what you get for cuts.. but i dont get it
Old Dec 4, 2009 | 09:29 PM
seabass202's Avatar
seabass202
yeah, I think you need the reverse cut gears. not because it's a high pinion or low pinion I mean the ring gear doesn't care where it contacts the pinion gear, it's the rotation. you can get a different carrier or thicker ring gear from summit racing.I hope others will chime in. this is a little out of my expertise.
Old Dec 4, 2009 | 10:50 PM
dsertdog56's Avatar
dsertdog56
High pinion/reverse cut gears are for Ford or other types with....well...the high mount pinion. Its the opposite of your Dodge. These guys have both.
http://completeoffroad.com/c-65143-g...-standard.html
Old Dec 4, 2009 | 11:40 PM
Dodge.Ismo's Avatar
Dodge.Ismo
Check out a great site for info and to buy parts: "Richmond Gears".
Old Dec 5, 2009 | 07:21 AM
olyelr's Avatar
olyelr
Yeah, you don't need reverse cut gears. They are for high pinion axles, which yours are not. Wherever you order the gears from, just tell them what axles you have and what gears you want... they will know what to send you.
Old Dec 5, 2009 | 10:03 PM
meanwhitemopar
you see last time i just told them what i have, and what i need, i got the wrong things... its what happen with my shocks... so i want to find a place i can get 5.13 reg cut, reg rotation, thick gears... this is a temporary regear until i get the money to put in the elockers( or arbs depending on how long i feel like waiting) and regear again, nd maybe 5.38...cause i dont want to mess with restuffing carriers.. unless i like the 5.13s
