I hate oil
Old Dec 5, 2009 | 11:03 PM
Miami_Son's Avatar
Miami_Son
Originally Posted by neattouch648
the **** was little tiny pieces of metal...probably from the screwed up bearings that were previously installed.
You just had the engine rebuilt and they didn't touch the oil pump or pickup screen to at least remove the debris? Any engine that needed rebuilding due to bearing failure should get a new oil pump. The tolerances on these things are so tight that if any metal, even soft bearing bronze, went through them they should be replaced.
Old Dec 5, 2009 | 11:52 PM
neattouch648's Avatar
neattouch648
well,i rebuilt the engine myself....i guess i'll pull the pump tomorrow and replace it...any way to replace it without having to pull the distributor and center shaft to prime it?
Old Dec 6, 2009 | 09:22 AM
dhvaughan's Avatar
dhvaughan
DON'T pull the distributor.
simply drop the oil pan and unbolt the 2 bolts that hold the oil pan to the bottom of the block. hold onto it so it doesn't hit you in the head. when reinstalling, use the thin paper gasket and be sure the shaft is engaged and that it sits flat against the block.
you don't need to remove the rear main cap - only the oil pump which is beside it.
edit - MAKE sure your distributor shaft is not broken. no reason it should be, but while its exposed, check it. it runs through the rear main cap.
looking for pic....
i can't seem to post this image inline, but its a good pic from rockauto of how it mounts.
http://info.rockauto.com/SealedPower...244166_ANG.jpg
here's some really good pics.
http://www.pavementsucks.com/tech-article-31.html
Old Dec 6, 2009 | 10:36 AM
neattouch648
okay well, when i replace the oil pump, do i have to prime it some how or will it prime itself just by me putting oil in it?
tHANKS
Old Dec 6, 2009 | 11:09 AM
dhvaughan's Avatar
dhvaughan
prime it. always prime the oil pump.
Old Dec 6, 2009 | 11:20 AM
neattouch648
how do i prime it?
Old Dec 6, 2009 | 11:28 AM
dhvaughan's Avatar
dhvaughan
^ read the pavement sucks thread i posted above.
Old Dec 6, 2009 | 11:59 AM
J415's Avatar
J415
+1 you never want mental on metal without lubrication.
Old Dec 6, 2009 | 12:09 PM
neattouch648
that link for some reason just takes me to the main "pavement sucks" page...
Old Dec 6, 2009 | 01:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Go to the link he gave you, hit tech, then go to rear main seal replacement.
