No overdrive...
Old Dec 7, 2009 | 06:01 PM
98 Ram "Hybrid"'s Avatar
98 Ram "Hybrid"
Originally Posted by Sheriff420
it is in its own "compartment", it is the overdrive unit that dodge added to the back of the transmission in the 90's. and it is electronically controlled so it could be an electrical issue.
Haha, I was pretty sure that's what I was thinking about... been having a rough week. Thanks for the quotations on compartment. It made me laugh.
Old Dec 7, 2009 | 06:04 PM
PurplDodge's Avatar
PurplDodge
Quoted from a Chrysler TSB:
At ambient temperatures of -20 C ( -5 F) or below, the Powertrain Control Module (PCM) will electronically inhibit the transmission from shifting into overdrive. This will protect the transmission from damage if the transmission fluid begins to freeze.
Old Dec 7, 2009 | 08:54 PM
offroadjosh's Avatar
offroadjosh
ahhh! thank you Purple!!
Josh
Old Dec 7, 2009 | 09:16 PM
CSXfan's Avatar
CSXfan
Transmission fluid can FREEZE? Wow, never heard that one before. Interesting.
Old Dec 7, 2009 | 10:39 PM
PurplDodge's Avatar
PurplDodge
Its a liquid.
Old Dec 7, 2009 | 11:10 PM
offroadjosh
Sooooo when its sub zero for 2 or 3 weeks... i have no 4th gear????? wtf!
Josh
Old Dec 8, 2009 | 02:46 AM
Sheriff420's Avatar
Sheriff420
i would think the 15 mile drive would have heated it up enough though. especially if you have the stock transmission cooler, that thing has some heat transfer from the coolant in the radiator going on.
Old Dec 8, 2009 | 06:40 AM
PurplDodge's Avatar
PurplDodge
Josh
Whats wrong with that?
Old Dec 8, 2009 | 11:24 AM
offroadjosh
Lol i get worse file mileage than i do when i have a 4th gear. Our hwy is 70 all the way to town and i also run fire calls so im sure running at 3500-4000K rpm isn't healthy for the engine.
Josh
Old Dec 8, 2009 | 03:23 PM
PurplDodge's Avatar
PurplDodge
3500 - 4000 RPM is good for long peroids of time can be bad, I wouldnt want to do that for more than 15 miles, but nearly frozen transmission fluid isnt good either. Maybe getting some heaters for your garage (If you have one), or stick a flat piece of canvas or cardboard over half the radiator like they do on the big trucks.
