46re shift kit & other questions
Old Dec 7, 2009 | 12:37 PM
nh5's Avatar
nh5
Default 46re shift kit & other questions
I'm planning to get some work done on the 46re. Planning a transgo shift kit at least. Possibly looking into changing the torque converter to one of better quality. What else should I do or look into if I'm gonna have it serviced?
Old Dec 7, 2009 | 01:00 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
External transmission cooler and Borg Warner bands.
Old Dec 7, 2009 | 04:17 PM
nh5's Avatar
nh5
I was planning to get a bigger pan. Aluminum one at least since the current one is starting to rust. The external transmission cooler what actually is it? Also where can I order the bands. I'm trying to get all the parts and I'm gonna take it to a trans shop a have them do it.
Old Dec 7, 2009 | 05:23 PM
SpcD1500's Avatar
SpcD1500
External Transmission cooler = a radiator for your transmission (easiest way to explain it)
Old Dec 7, 2009 | 11:16 PM
BigRedRam95's Avatar
BigRedRam95
I am going to put the same shift kit in my transmission I also would like to know where to get the bands.
And a External Transmission cooler=
Old Dec 7, 2009 | 11:35 PM
SpcD1500's Avatar
SpcD1500
+1 i was going to find a pic for him but lost interest in it when i got to flicker and figured someone else would post one hahaha
Old Dec 8, 2009 | 08:52 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Just ask the transmission shop to source the bands. It would be more convenient and chances are that you'll pay them the same price it would cost you to buy them, including the shipping.
Old Dec 8, 2009 | 09:44 AM
meanwhitemopar's Avatar
meanwhitemopar
one thing i found usefull... any trans cooler will work... i got mine of an F350 in a junk yard... its simple to bolt them in place, nd run two lines... add a little more fluid to your trans and your good... now i need to add the trans temp gauge... good way to keep an eye on it...
Old Dec 8, 2009 | 03:11 PM
dodgeram07's Avatar
dodgeram07
maybe a 3.8 ratio kick down lever for the band... I believe that the size just bigger than stock
Old Dec 8, 2009 | 04:46 PM
wjxavier's Avatar
wjxavier
i honestly don't think a extra tranny cooler is needed unless you happen to do more towing or offroading than usual. the stock one should be sufficient enough. just remember to take out the check valve.
