Problems with 1996 Dodge Ram 1500 4x4 (help Please)
Old Dec 7, 2009 | 08:47 PM
dodgeram945's Avatar
dodgeram945
Default Problems with 1996 Dodge Ram 1500 4x4 (help Please)
I have a 1996 Dodge Ram and I am having problems with it. The problem I am having seems to be after I start it for the first time in the morning. The engine starts right up but after it runs it starts sputtering and stalls out. If you let it sit for about 10 minutes after it stalls it will start right back up and if you try starting it right up it just turns over. It seems to happen when the temp gauge shows temperature. If you feel the radiator hose it's still cold but the heater hoses are both hot. I'm not getting any codes and can't figure out what is going on. Any ideas would be greatly appreciated.
Old Dec 7, 2009 | 08:50 PM
95RAM360's Avatar
95RAM360
I think this is the IAC issue...not sure though. try cleaning it.
Old Dec 8, 2009 | 01:38 AM
dodgeram945
Thanks for the tip. I'll give it a try and see what happens.
Old Dec 8, 2009 | 10:36 AM
scottnfwi's Avatar
scottnfwi
I had a 92 pontiac grand prix that it would run fine for about half hour and then stall out but you would have to wait hours to start it again.I tracked it down to a faulty injector and the computer would shut it down. might look there.
