Fuel sync?? Distributor off??
Old Nov 19, 2009 | 05:21 PM
Activate's Avatar
Activate
Default Fuel sync?? Distributor off??
I started my 410 today and in ran only on a few cylinders!!(It sound like it)
It wouldn't run att all, I can get it over 1200 RPM
I have checked for errors in the ECU but there are no errors.
I have rechked the wiring and that is a real pain in the *** with the Kenne Bell on and it looks that it is ok.
Before we installed it whe have cheked TDC it is in line with cyl1.
What have I done wrong?
Thanks and greetings,
Erik.
Old Nov 19, 2009 | 05:34 PM
Sheriff420's Avatar
Sheriff420
probably a plugged catalytic converter.
did you mean can't get it over 1200 rpm?
what is a 410?
what is a kenne bell?
Old Nov 19, 2009 | 05:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The fuel sync has to be set with a capable scanner tool.
Old Nov 19, 2009 | 08:50 PM
dodgeboy7's Avatar
dodgeboy7
what is a 410?
Kenne bell in a super charger i dont think they make them any more from our trucks and whats a 410 you mean 408
Old Nov 19, 2009 | 09:45 PM
aim4squirrels's Avatar
aim4squirrels
408 that is bored .030 to clean up the cylinder walls actually equals 410ci, IIRC.
Old Nov 20, 2009 | 04:39 AM
Activate's Avatar
Activate
It is a bored over 408 indeed.
The cat is already gutted so that can not be the problem.
I have built this engine put it back in and tried to start it it and this is the problem right now.
How can I check the feulsync?
Erik.
Old Nov 20, 2009 | 07:25 AM
aim4squirrels
You need a scan tool such as a Snap On the the dealerships DRB-III. I don't know if an Auto Xray brand can do it.
Raise the idle to 1000 RPMs, loosen the disty hold down clamp, twist the disty slowly until you reach the desired fuel sync.
The range is -10 to 0 to +10. Zero is where it's set stock. I have heard that -4 is a good setting for a blower, but I've never had one personally to experiment.
Old Nov 20, 2009 | 07:49 AM
moparama's Avatar
moparama
Maybe 180* off?
Old Nov 20, 2009 | 08:25 AM
95RAM360's Avatar
95RAM360
Originally Posted by moparama
Maybe 180* off?
+1 thats what happened when i did the tiing chain in my 93 Nissan 4x4, and it did the same thing you described
Old Nov 20, 2009 | 09:12 AM
Sheriff420's Avatar
Sheriff420
gotcha.
why do they call it a 408 if its actually a 410?
