trans won't shift until 4700rpm
Old Dec 7, 2009 | 08:54 PM
part timer's Avatar
part timer
Default trans won't shift until 4700rpm
99 1500, 5.9, 4x4, trans won't shift from 1-2 until about 4700 rpm, will shfit from 2-3 & 3-o/d fine. replaced governor pressure sensor about 8,000 miles ago filter gets changed every 30,000-35,000. speedometer won't show a speed until about 30 mph. it has been that way for 2 years now and the trans has been shifting just fine. will the speed sensor screw with the trans.?
Old Dec 7, 2009 | 09:02 PM
95RAM360's Avatar
95RAM360
how many miles?
these Rams have a rep for trannys going, if you make it to 150K on an original tranny, you're considered lucky....
not to discourage you...
Old Dec 7, 2009 | 09:16 PM
part timer's Avatar
part timer
174000 miles, i thought they redesigned the check ball/valve that was sticking in the 1st gen trucks
Old Dec 7, 2009 | 10:00 PM
95RAM360's Avatar
95RAM360
it may be time for a rebuild to tell you the truth
how does the fluid smell?
