Questions about transmission in 2500
Old Dec 12, 2009 | 07:16 AM
peterfromme's Avatar
peterfromme
Default Questions about transmission in 2500
There is a 2500 w/V10, 4x4 that is still available that I'm still considering.
What transmission does the 2500 have? Is it known to better better or as bad as the 46RE that is in the 1500?
thanks,
pf
Old Dec 13, 2009 | 05:14 PM
peterfromme
Default Thanks so much for the help
1 simple question....no response. Thanks!
Old Dec 13, 2009 | 05:31 PM
notanexit7's Avatar
notanexit7
I think its the 47re. they have the same weak points but they aren't as bad if I'm not mistaken
Old Dec 13, 2009 | 06:19 PM
Miami_Son's Avatar
Miami_Son
Pretty much correct. The 47RE is a much better tranny than the 46Rx, but they still have a few issues.
Old Dec 13, 2009 | 07:24 PM
Bob5151's Avatar
Bob5151
The V8 2500's got the 46re (or rh), while the V10 and diesel trucks got the 47re, is that correct? What about V8 3500's, did they get the 46 as well?
Old Dec 13, 2009 | 08:02 PM
Miami_Son's Avatar
Miami_Son
Yes.
Not sure, as all the 2nd gen 3500s I've ever seen had diesel or V10 engines. The 2500s with V8 were classified as LD (Light Duty) trucks, so I don't see them putting a V8 in a 3500, which are all classified as HD trucks.
Old Dec 13, 2009 | 09:21 PM
95RAM360's Avatar
95RAM360
when i had my electrical problem i went to the junkyard to look at the way the rams were wired, and i was looking at a 3500 V8 5.9, and the tranny was a 46RE
Old Dec 14, 2009 | 08:54 AM
notanexit7's Avatar
notanexit7
wow I wouldn't buy a heavy 3500 with a 46re in it. was it a dually?
Old Dec 14, 2009 | 09:56 AM
95RAM360's Avatar
95RAM360
no it wasnt a dually
Old Dec 14, 2009 | 11:34 AM
fjmg's Avatar
fjmg
My understanding is that the 46 was behind the 5.9 mag and the diesel/v10 used the 47 while the newer diesels get the 48. The only real difference is the # of clutch discs (which req'd a larger drum) but you can get kits with thinner discs and steels to allow an increase in # of clutches in the std drum.
