re-gearing my 98 1500
Currently i have a 5'' suspension lift and a 3'' body lift with 38.5x14.5 tires on my 98 ram 1500. I need to re gear the axles but i really don't know much about it. What ratio should I get and how much will it cost? any advice would be greatly appreciated.
5.13 is another option, but 4.88 sounds right.
call randys ring and pinion and you can find out exactly what its going to cost with gears, install kits and bearings. for my 4.10 gears with a new front carrier, master install kits for both axles and the side adjuster tool for the rear end its going to cost me 1000$.
http://www.ringpinion.com/
i just had my 4.56 installed. i had a shop do it for me so i couldnt tell you. ik that you want to get ur preload and backlash right and all the precise meaurments or ull burn those gears up real quick
Trending Topics
thats wat i thougth. you would have to go to D60s front and back to go higher than 4.88. and that wouldnt be a bad idea since u have 38s on ur truck. the 44 and 9.25 dont like anything much bigger than 35s
ur best bet is to take it 2 a garage there lots of special tools involved and dont quote me on this but some of the dodge rear ends u actually have to spread the diff with this special vice tool 2 get the diff out easyily but i cant remember what year and size rear end
