What is normal temp with 180.
I totally understand that but if the TB is the regulating factor as it should be than why would a high flow air filter mess everything up?.....Lets face it k&n uses the same high flow filters on many different vehicles with different size engines without issues.....a 14X3 is a generic filter size as well...
unless the stock tb is already not restrictive enough in some cases because of other factors like carbon buildup or a half plugged exhaust preventing the flow from getting through and out of the engine right?
Will the magnaflow cat. and some aftermarket exhaust help with the out flow? Combine the high flow air filter with better pluming let it breath better? hmmm...
I have a cai and my truck runs fine except once in a while when its cold and damp...(I think its the iac like mentioned in another thread... I have aheaders and a highflow dual exhaust and what looks like a fairly new cat as well so...
