RPM Gauge
Old Dec 14, 2009 | 06:16 PM
JyHawks's Avatar
JyHawks
Default RPM Gauge
my 97 5.9 360 doesn't have a Tach and i want one cause it's driving me nuts, question is how to hook one up, thanks for any help
Old Dec 14, 2009 | 06:55 PM
95RAM360's Avatar
95RAM360
run a wire to the coil, one to a ground, one to a power source, and one wire to illuminate it.....VERY easy job.
i think it gos like this on aftermarket tachs
Green Wire- Goes to coil
Red Wire- Power
Black Wire- Ground
White wire- Illumination
Old Dec 15, 2009 | 03:28 PM
JyHawks's Avatar
JyHawks
ok coil as in ignition coil? how do you wire that in,
Old Dec 15, 2009 | 03:38 PM
PurplDodge's Avatar
PurplDodge
Cut, splice, put some heat shrink tubing on the wire, solder the wires together, and place the heat shrink over the solder-ed area, then using hea, shrink the tubing!
Old Dec 15, 2009 | 03:48 PM
95RAM360's Avatar
95RAM360
i easy terms, use a 3 way wire adaptor to tap into the ignition coil wire. dont cut the wire just spread the insulation, tap into it with the connector, and get something over it that will protect it from heat lol
Old Dec 16, 2009 | 12:36 AM
barracudadave67's Avatar
barracudadave67
Remember ....... the green wire goes to th neg wire on the coil.
barracudadave67 aka Dave C.
Old Dec 17, 2009 | 11:11 PM
JyHawks's Avatar
JyHawks
thanks for the help guys!!!!
Old Dec 18, 2009 | 01:21 AM
Silver_Dodge's Avatar
Silver_Dodge
Soldering the connection is really the best way to go though.
