hitch question (i feel stupid)
Old Dec 17, 2009 | 10:33 PM
Bubba39047's Avatar
Bubba39047
Default hitch question (i feel stupid)
Ok quick question. will a reciever hitch (mopar) from a 3/4 ton 2500 ram fit on a half ton 1500 ram?
Old Dec 18, 2009 | 12:42 AM
dakotas ram's Avatar
dakotas ram
hmmm, dont know, i know the frames were somewhat different, but i would think that they are the same widths
Old Dec 18, 2009 | 12:51 AM
95MaroonMonster's Avatar
95MaroonMonster
yea it would fit
when i put the hitch on my truck, the book at rural king listed the same hitch for all 1/2 3/4 and 1 ton trucks
Old Dec 18, 2009 | 01:40 AM
Bubba39047's Avatar
Bubba39047
man thats some good news. Thanks yall
Old Dec 18, 2009 | 12:00 PM
sungod's Avatar
sungod
It will fit and in reality it is a better application. The OE hitch is only rated for 5000lbs even though the 2500 can have a 8700~9100lbs towing capacity. I am sure the hitch is as strong as any of the aftermarket hitches with higher ratings, but if you go to rent something that is 6000 lbs, you are going to get turned away with the OE hitch even though you have a truck that is rated to tow it. They 1500s towing capacity is 3500~5000lbs.
Old Dec 18, 2009 | 02:51 PM
Bubba39047's Avatar
Bubba39047
well im not going to tow heavy loads, but i tow stuff with ball sizes from 1 7/16 to 2 and 7/8's. plus on the small trailers the back end is practically dragging from being on my bumper. not to mention turning radious.
Old Dec 20, 2009 | 07:04 PM
Bubba39047's Avatar
Bubba39047
ok i got the hitch and it bolted right up to mine. so the 3/4 ton hitch will fit on a 1/2 ton
Old Dec 20, 2009 | 08:08 PM
PurplDodge's Avatar
PurplDodge
Um...Wrong!
The factory hitch and the Mopar one are a Class IV hitch rated for 10,000 pounds.
A 1500 like mine is rated to tow around 7000 pounds. If I had my owner's manual with me I could tell you.
And to the OP, yes, it will fit. The Mopar one I got came off a 1996 Ram 2500.
Old Dec 21, 2009 | 01:35 AM
Bubba39047's Avatar
Bubba39047
now your both right. the hitch it says, and i quote (i quote a hitch lable) "5000lb dead trailer weight, 500lb toung weight. 10,000lb with weight distr. hitch, 1000lb toung with weight distr. hitch"
