Horn doesn't work on my 98 Ram
Old Dec 18, 2009 | 02:32 PM
gwo1973's Avatar
gwo1973
Default Horn doesn't work on my 98 Ram
I'm new here, I have a 1998 Dodge Ram 2500 Sport, Intense Blue V8.
I have traced it up to the steering wheel. I can make it honk in the harness by grounding it out. My cruise works and the air bag light is not on. Is this a clock spring problem or a horn button problem? Any ideas or suggestions deeply appreciated. Thanks.
Gary
Old Dec 18, 2009 | 02:43 PM
bigdodge2006's Avatar
bigdodge2006
if it has the two buttons on both sides and neither one is working but you can ground it out more than likely it is not the buttons. I would check for a broke hot wire by the air bag, but i have been extremely cautioned not to unplug the airbag for you may deploy it upon reconnection. keep me posted
jeff
Old Dec 18, 2009 | 02:50 PM
gwo1973's Avatar
gwo1973
The horn button is molded in into the cover unlike the older ones that had a buttons on each side of the wheel. From what I have read you unhook the battery, let it set for 2-3 minutes to de-energize before unhooking the airbag.
Old Dec 18, 2009 | 03:00 PM
bigdodge2006
Yes, that i have heard of too i have a 97 with the two buttons on the sides. could not remember if they stopped them in 98 or 97 obviously 97.. sorry not much help and welcome to dodgeforum
Old Dec 18, 2009 | 03:29 PM
gwo1973's Avatar
gwo1973
97 was the last year for that style. 98 got a new steering wheel.
Old Dec 24, 2009 | 12:26 AM
hydrashocker's Avatar
hydrashocker
You are in a dead area and you need to post in your era of year of make.
2nd Gen Ram
1994 through 2001 Rams
~Rustin~
Old Dec 24, 2009 | 01:16 AM
Bubba39047's Avatar
Bubba39047
similar problem with my friends 96 caravan. cruise and the horn wont work, but the horn works when you lock it with the keyless and the panic button. so we took it to the local dealer and they susperct clockspring so they ordered one and are going to repair it when it comes in. so id guess it be the same
Old Dec 24, 2009 | 01:32 AM
2001Ram's Avatar
2001Ram
There was a HUGE recall on the Caravans clocksprings. Might want to check into that before paying!
Old Dec 24, 2009 | 01:59 AM
Bubba39047's Avatar
Bubba39047
we know, because it being that recall they are doing the repairs for free
Old Dec 22, 2012 | 10:50 PM
dbutton1990's Avatar
dbutton1990
I have the same truck as you...my horn doesn't work unless you push down very hard in the center of the steering wheel. Good Luck!
