Error Code 31
Old Apr 15, 2005 | 02:59 PM
CanadianRAM's Avatar
CanadianRAM
Default Error Code 31
Thanks for the previous postings about the error codes.
My check engine light had been going off and on intermittantly for the last year. After a couple trips to the mechanic to read the codes and for minor fixes it still is on, this last time it has not gone off for the last 3-4 months. After checking the codes myself I get an error 12 and 31.
12 - Direct battery input to PCM was disconnected within the last 50 key-on cycles
31 - Evap purge flow monitor failure or evap solenoid circuit
Any help with either of these as to what I need to do or have fixed would be appreciated!
Cheers
Old May 27, 2005 | 03:32 PM
CanadianRAM
Default RE: Error Code 31
No takers? Hmmm
Old Nov 4, 2006 | 08:14 PM
kurts2's Avatar
kurts2
Sorry you never got an answer to such a simple question. I am new to this forum and stumbled on this. Well if you don't know by now, the bat disconnect will NOT cause your ck engine light. It is an advisory code only and only seen if you read your codes. It lets you know the bat was disconnected within so many key cycles. My intrepid always has this fault (if I read the codes because as I said, it will not cause the ck engine light). This leaves the code 31. This is an emissions component used to capture gas fumes that evaporate in you fuel system (gas tank primarily) and then burn them. It is a simple system that consists of a charcoal canister and some hoses. I won't go on any further unless you need info still. Let me know.
Kurt
