Misfires and vacuum leaks
Old Dec 19, 2009 | 12:59 PM
micahwfmh's Avatar
micahwfmh
Default Misfires and vacuum leaks
hey i am from alabama.i have a 1996 dodge ram 1500 2wd quad 5.9 magnum i have done some new things on the dash with new colors and new electronics a very hard hitting system ive put a roll bar and im about to install a canvis cover on the bed im haven some problems with random miss fires and a load air sucking sound and some back firering sound out of the throttle body and ideas
Old Dec 19, 2009 | 01:37 PM
offroadjosh's Avatar
offroadjosh
Well when was your last tune up? (plugs, wires, cap, rotor..etc). I am thinking the IAC is causing that. Plus odds are your plenum is leaking. My best bet would be IAC though. Maybe a bad TPS? Btw use the search button it helps. Seems to be working today lol.
Josh
dakotaff's Avatar
dakotaff
Welcome to the site. Post this question in the 2nd Gen Ram section, and they can help you out.
Old Dec 19, 2009 | 06:27 PM
micahwfmh's Avatar
micahwfmh
i hvae put new plugs wires and idel air control sencer on it and it still shows random miss fires and sounds like sucking air and makes a poping noise like a back fire
Old Dec 19, 2009 | 07:49 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Dec 19, 2009 | 08:07 PM
halfamil's Avatar
halfamil
Distributor cap and rotor,spark plugs should fix it.
Old Dec 19, 2009 | 08:34 PM
95RAM360's Avatar
95RAM360
if the #5 and #7 wires touch they will cause misfiring for they fire right after each other.and your plenum 99.9% chance its blown. this can foul plugs, clog the CAT, kill the 02 sensors and make it run like crap
Old Dec 20, 2009 | 02:16 AM
dakotas ram's Avatar
dakotas ram
throwin any codes?
Old Dec 20, 2009 | 09:06 AM
micahwfmh's Avatar
micahwfmh
i took it to auto zone and they hooked it up and said that it is haven random missfires on all 8 ,and as for codes im not sure this is all i know lol,i have put a new coil,new plugs,wires,idel air control sen, but it still does the random missfires and very bed mpg,and still the load sucking sound like a big vacum leak im not a mech. so im not up with all the codes and stuff that you all have said lol but im really looking to get some help on this cause its a good truck well has been, and ty to all that have wrote me back on this i think i just need to suck it up and take it to a shop
