Truck won't shift into 3rd
Old Dec 20, 2009 | 07:52 AM
05horse's Avatar
05horse
Default Truck won't shift into 3rd
hey guys names keith im from ohio
i got 2 dodge rams, a mustang and a 77 trans am ( currenty on the chopping block for sale or trade )
anyways 2001 dodge ram, 1500 5.2L 2WD
246,XXX miles. wont shift int to 3rd.
acting like its low on fluid but its not. before i pull the trigger o
n a new trans, is there anything i should check?
vac lines, sensors etc etc?
Old Dec 20, 2009 | 09:31 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Dec 20, 2009 | 12:43 PM
Augiedoggy's Avatar
Augiedoggy
cold be the governer pressure soleniod and sensor....when they fail the truck goes into "limp home" mode and you only hve first and second gear....do a search and you will find all the info you need on it...I've done it myself...usually you get a 1741 code with a scanner..
Old Dec 20, 2009 | 01:32 PM
05horse's Avatar
05horse
http://www.autozone.com/autozone/cat...questid=474461
is that it?
man $133, id hate to buy one and it not be it!
now could i go buy one out of a trans at a junk yard give it a try and if it works go buy a new one, or is this one of those things that you really dont wanna swap from truck to truck
Old Dec 20, 2009 | 01:52 PM
xjarhead69's Avatar
xjarhead69
Try this place, http://www.transmissionpartsusa.com they should have better price than that.
Dave
Old Dec 20, 2009 | 01:54 PM
05horse's Avatar
05horse
awsome thanks, now what kind of trans do i have?
Old Dec 20, 2009 | 02:05 PM
xjarhead69's Avatar
xjarhead69
I do beleive it is the 46RE transmission in there the same as my 96 has. Hopefully others can chime in to conform that.
Dave
dakotas ram's Avatar
dakotas ram
should be 46re
Old Dec 20, 2009 | 04:27 PM
xray99's Avatar
xray99
You can get the sensors for far less than that.
Ebay is one option, local tranny shops maybe even better.
So I'm guessing that it isn't low on fluid then.
Could be a number of things, sensor related or mechanical.
Might look into adjusting the throttle cable in small increments, if that cable gets the smallest bit out of adjustment it plays havoc with shifting.
If you have a garage, might be worth while to drop the pan and change the fluid & filter, see if that helps.
If not, I'd try to get access to a quality scan tool and see if that'll diagnose your problem.
I wouldn't just go throwing sensors at it without knowing if that will help or not.
Old Dec 20, 2009 | 05:35 PM
lord0fsal3m's Avatar
lord0fsal3m
i just had a similar problem, took it to a tranny shop and they replaced the govorner pressure sensor and solonoid for $350
