Remove back glass
Old Dec 20, 2009 | 04:23 PM
m_ross05's Avatar
m_ross05
Default Remove back glass
I was told to remove my back glass that I need to take out the back interior panels to unbolt the window. But I cannot figure out how to remove the panels because the seat belt slide things are bolted onto the body and it seems they have to come off for the panels to come off. Any response is appreciated
Old Dec 20, 2009 | 06:52 PM
BigRedRam95's Avatar
BigRedRam95
When i took out mine i had to take all the trim around the window out and there is tabs around the window that have to be bent out.
Old Dec 20, 2009 | 10:00 PM
m_ross05's Avatar
m_ross05
you mean from the inside or the outside?
Old Dec 21, 2009 | 10:53 AM
BigRedRam95
For the inside also get the right tool to take the window out or you will bend the frame of the window and will never get it to seal right.
Old Dec 21, 2009 | 11:58 AM
Sheriff420's Avatar
Sheriff420
all you have to do is bust the porcelain off an old spark plug then toss it (the porcelain, not the plug) at the back window, gently for a good show. then break out the shop vac and suck up all the pieces and peel the window trim away from the body and you'll be good to go.
