Crazy Squeeling Problem
I had the same problem with mine turned out being a misaligned pulley. According to Dodge I had a bolt loose on the PS pump when the belt was off everything was perfect. when the belt was installed the squeaking would start, drove me up the wall. I finally left the truck with Dodge they spend 2 days tracing the problem to a flipping bolt. since that time no squeak.
Mine is doing the same thing, I will check out the pulleys to see if they are OK, this just started about a week ago, along with my cat conv rattling like hell, oh well, it will give something to do over the X-mas holiday.
I took the belt off to go and exchange it and checked all the pulleys and they seem to be in align, the guy at advance said that when I had the water pump replaced it could have been put on with out the shims, or something like that, i didn't know these water pumps had shims. well anyway the pulley for the water pump is wide enough for the belt to ride one way or the other. Put the belt on and the problem is gone for now.
