I did my wheel bearing JOY!!!!
Old Dec 21, 2009 | 11:46 AM
iwhitne's Avatar
iwhitne
how hard is it to do the outer axle seals? i think i need both of my axles done.. I've seen a few drips of diff fluid on my tires after sitting a for a few days
Old Dec 21, 2009 | 12:37 PM
rumble_truck's Avatar
rumble_truck
i had to do my wheel bearing about a month ago, how did you get the hub out? use a puller?
My buddy went to put a 3-jaw puller on it, and broke the puller. in the end i put the bolts in back side of the hub and hit them with a hammer. pain in the *** >.>
Old Dec 21, 2009 | 12:56 PM
JoeV10's Avatar
JoeV10
The easiest way I've found to do it is to bend the tab up on the brake backing plate and dump penetrating oil in the slot under it. Then wedge a socket and and a short extension between the hub bolt and the axel. Using the truck's power steering you turn the wheel into the socket and it pops free. I don't know how well this would work on the 1500 as I believe they have 3 bolts in place of the 2500/3500's 4. Just my $.02
Old Dec 21, 2009 | 03:52 PM
99DRAM31887's Avatar
99DRAM31887
i got a flat head screwdriver and a hammer and chiseled around it and wiggled it free it slid right out
Old Dec 21, 2009 | 04:21 PM
Relex's Avatar
Relex
The first time I did both my wheel bearing I just used an air chisel.
Old Dec 22, 2009 | 04:52 AM
99redram318's Avatar
99redram318
Im not looking forward to them on my 2wd :-/
