Leveling kit is a go!
Old Dec 23, 2009 | 01:15 PM
  #21
Augiedoggy's Avatar
Augiedoggy
Originally Posted by W8 a minute
I don't understand why a shock extension is not included with these leveling kits. If you add a spacer to the spring you don't gain any additional travel so a longer shock is not needed. A simple extension for the stock shock is all you need.
one reason is cost....many who buy the leveling kits are price minded and looking for lift on a budget.... plus the right way would be to really replace the shocks anyway if you want extenders buy them seperate? why waste them with every spacer kit sold when many wont get used...
too bad your so far from me offroad josh I have an almost brand new set of black cragers off my ram I'm looking to sell....
Old Jan 9, 2010 | 04:10 PM
  #22
mudxslinger's Avatar
mudxslinger
i have 305's on my 96 dodge 2500 right now with no lift or leveling kit and its not rubbing ...soon to be 2.5" leveling kit and 35" tires
Old Jan 9, 2010 | 04:53 PM
  #23
95MaroonMonster's Avatar
95MaroonMonster
b/c most of the spacers dont even require new shocks (i have a 2 inch on the front of my truck and have factory length shocks under it)
Old Jan 9, 2010 | 07:30 PM
  #24
360mag45's Avatar
360mag45
so how is this leveling kit comeing along did you get your rims yet
Old Feb 12, 2010 | 09:35 PM
  #25
95GreenMachine's Avatar
95GreenMachine
You can run 305's stock with a 2.5 inch leveling kit. Depending on the brand you could even run 35''s
Old Feb 12, 2010 | 10:51 PM
  #26
Miami_Son's Avatar
Miami_Son
Yep, same here.
Old Mar 3, 2010 | 07:52 PM
  #27
95GreenMachine
Default 305's
Josh, you can easily fit a 305 and maybe a 315. 305 measure out to only be 32.8 inches in diameter. I am putting a HBS 2" leveling kit on my 95 1500 Ram this weekend and when I talked to HBS, they said I could run 35's with no rubbing at all. Also you talked about shocks earlier too. You can run with stocks but if you have stock shocks on a second gen and have the money, go ahead and replace them. I have 4 Pro Comp ES3000 shocks sitting at my house. Got them from 4wheel parts for about $137. Good deal. Good luck with the kit but you can easily fit 305's on your truck
