Hood Latch Broken - Hood stuck down
Old Aug 1, 2013 | 02:50 PM
Sheriff420's Avatar
Sheriff420
Does the latch line up with the bar that goes into it? It might be an alignment issue if you can close the latch with a screwdriver and make it pop open again with the hood release.
Old May 9, 2014 | 06:00 PM
impius_orcus's Avatar
impius_orcus
your advice was good but not clear enough for me to find it, i dont know if i can post a link or not but this picture from a dodge recall on hood latches helped me alot
http://dodgeram.info/tsb/recalls/638/fig1.jpg
and here's the main page it's located on
http://dodgeram.info/tsb/recalls/638.htm
Old May 16, 2014 | 09:16 AM
Sheriff420's Avatar
Sheriff420
I had a problem with that secondary latch rod the other day. There is a plastic clip that keeps the rod attached to the secondary latch and that clip broke. The bar fell out of the secondary latch and wouldn't stay in place. I put the bar back through the secondary latch and wrapped some tape around the end, then I put a hose clamp on the tape and now it's staying in place.
Old May 16, 2014 | 09:23 AM
Wasn't there a recall on those?
