fuel pump and wheel bearing question
Old Dec 24, 2009 | 06:34 PM
helms's Avatar
helms
Im guessing since your truck is OBD1 that they will be different. oh well.
Old Dec 24, 2009 | 09:00 PM
95RAM360's Avatar
95RAM360
yea its OBD1...i dont want to drop the tank cuz w have alot of snow on the ground, and i cant do it now.
Im injured from being crushed between two cars at work (tore my miniscus) so i cant do it there.
and im milking this, im getting 300 a week for doing nothing, plus i have a lawsuit lol, and i can walk fine.
Old Dec 24, 2009 | 09:53 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by 95RAM360
it moves about an inch back and forth and up and down, do you think it will last the 600 mile trip? its all highway i mean it runs smooth as hell, and it only hops when going slow. if i have momentum it doesnt hop at all.
AN INCH !!!!! hell no, don't drive it anywhere till you fix it.
you might even **** up the outer axle shaft.
you have to fix it - or drive something else.
Old Dec 24, 2009 | 10:52 PM
dodge15004x45.9's Avatar
dodge15004x45.9
That is not something you go running your mouth about.
Old Dec 25, 2009 | 08:34 PM
dhvaughan's Avatar
dhvaughan
^ as the health coordinator reads this and notifies the private investigator....
might want to zip it.
Old Dec 27, 2009 | 07:14 AM
95RAM360's Avatar
95RAM360
i dont care...my boss is actually the one who said file a lawsuit (my boss is the boss for that store, not the company. and he hates the district manager.)
Theres nothing they can do anyways, Doctors orders, he says i cant go back till i go through physical therapy. They have an MRI showing my miniscus is torn. im lucky to still be able to walk but if i stand up for longer than 20 mins, my leg locks up. (kinda like an intense dead leg) so its basically 20 min on, 20 min off.
And I did make the 617 mile trip without problems. didnt even hop once. Im getting an Alternator monday for my g/f's maxima, then my truck is comming off the road until my whole front end is built up.
the cool part is that i filled it before i left (64 bucks) then i went 617 miles, and only had to put in 30 bucks on top of the 64, so 94 bucks and i made it 617 miles, and she still has gas (i think) but my gauge is messed up so i dont know.
Old Dec 27, 2009 | 11:21 AM
Cartalk2's Avatar
Cartalk2
95RAM360
QUOTE "2. im trying to figure my gas gauge out still, so my question is when using an ohm meter on the fuel pump (instead of dropping the tank)im going stick the ohm meter in the connector on top of pump. so the reads should be high ohms if its empty and low ohms when full right?"
"its stuck on full thats why i ask, it should be nearly empty, so i should be able to tell if its fuel pump related or not by doing this right?."
I think you are correct with ohm readings. Probably in the 120 ish range empty and 10-20 ish full. My gage stays at E, I had about 120 ohms empty and filled tank and still had about 120 ohms, thus I feel it is the sending unit.
Here are a couple off site links that maybe of some interest. Good Luck
Dodge
http://autorepair.about.com/library/faqs/bl463f.htm
GENERIC
http://autorepair.about.com/od/fixityourself/ss/fuel_sender_rpl_3.htm
FORD
http://autorepair.about.com/library/faqs/bl845g.htm
FORD
http://autorepair.about.com/library/faqs/bl664g.htm
Old Dec 27, 2009 | 05:18 PM
PlrBrr's Avatar
PlrBrr
Ha i have had my miniscus put back together once, some of it taken out and i am now on my 3rd ACL now. rehab and phisio is the most important thing right now. i just got back form a deployment and now i have a piece of bone under my knee cap tendon thinking aobut getting it removed. its sucks but o well
