Radio antenna switch?
Old Dec 25, 2009 | 01:33 AM
Mudbone25's Avatar
Mudbone25
Default Radio antenna switch?
I cant seem to ever get a station that my FM transmitter for my Ipod will work with. I found online that some people have had disconnected their antennas so that there wont be any interference. would it be possible to put a switch between the radio and antenna so that it wasn't permanently disconnected.
Old Dec 25, 2009 | 01:57 AM
Cheat's Avatar
Cheat
http://www.crutchfield.com/p_142FMMO...2.html?tp=1701
Thats what you need.
Old Dec 25, 2009 | 06:20 AM
Sheriff420's Avatar
Sheriff420
look around the 88's and 89's. 88.1 works with the transmitter i got for my g/f from up to about 30 foot away. you need to find a station that isn't getting a signal from any radio stations. if you try stations that are getting a signal then the transmitter and the signal coming through the airwaves will be fighting each other.
Old Dec 25, 2009 | 09:28 AM
Mudbone25's Avatar
Mudbone25
yeah i now that much, all the low band stations are clear in my area. the transmitter lets you select any station. but there all clear.
Old Dec 26, 2009 | 07:39 AM
Sheriff420's Avatar
Sheriff420
does your radio have a 3.5mm jack on it? using a double ended headphone cable is a sure fire way to have zero interference.
Old Dec 26, 2009 | 01:49 PM
Mudbone25's Avatar
Mudbone25
nope no jack thats why i use the transmitter. I never use the radio so i think I'm just going to try disconnecting the antenna.
