Lift blocks and body mod
Old Dec 28, 2009 | 05:29 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by Gav1n8
shackle lift it. It's easier and safer. Cost the same. Ebay shackle lift. Theres DIY links throughout google. If you got a jack, and a BFH (big Fing hammer) you can do it.
ditto.... 2" shackle lift is a better idea dont have the axle wrap to worry about...never used one on a ram yet but used them on my jeep and they worked well.... I dont see how the ones previouly posted could be so bad....
Old Dec 28, 2009 | 05:42 PM
dakotas ram's Avatar
dakotas ram
ah, i see the problem you speak of....what about flipping the hanger?
Old Dec 28, 2009 | 06:04 PM
dodge15004x45.9's Avatar
dodge15004x45.9
^ wouldn't that just be a shackle flip?
Old Dec 28, 2009 | 06:07 PM
011500Ram's Avatar
011500Ram
You would need a very long shackle in that case then. There is a company out there that makes a flipped shackle for these trucks. BDS I think it is. I think it uses the factory shackles as well.
Old Dec 29, 2009 | 02:00 PM
rwilhelms's Avatar
rwilhelms
So If I buy the shorter shackles from ebay Ill need something else then?? If I needed something else would it just be more worth my money to get AAL's or blocks?
Old Dec 29, 2009 | 02:03 PM
dakotas ram
i dont know, i just looked at my truck and i really dont see those shorter shackles being a problem
Old Dec 29, 2009 | 02:27 PM
011500Ram's Avatar
011500Ram
I wouldn't use those shackles at all. They will literally destroy your leaf springs over time. Dakota, compress the rear suspension all the way and you will see what I am talking about.
Just build a new hanger. Easy.
Old Dec 29, 2009 | 03:22 PM
rwilhelms's Avatar
rwilhelms
I havent had time to go out and look at my truck but wut do you mean by build a new hanger? I work in a machine shop so building something is no problem I just dont understand what your telling me to build?
Old Dec 29, 2009 | 03:27 PM
dodgeram07's Avatar
dodgeram07
what about a add a leaf?? thats about 2in lift
because if you lift to front 3in then lift the back i in it should be level
edit i was editin it and hit save and had forum problems
011500Ram's Avatar
011500Ram
Take a look at your hangers. See how they are in the shape of a "J"? Make ones that are more or less the shape of an "H", so the bottom is opened.
This:
Better off not lifting in that case then.
http://www.pirate4x4.com/forum/showthread.php?t=537571
