viper alarm wiring??
Old Dec 30, 2009 | 07:26 PM
BigRedRam95's Avatar
BigRedRam95
have you down loaded this 2001 shop manual https://dodgeforum.com/forum/2nd-gen...tmas-guys.html it has wiring diagrams in it. I am going to look in my paper manual now and let you know if i find one.
Old Dec 30, 2009 | 09:04 PM
skostur79's Avatar
skostur79
relays will be need if you going to use the alarm/rstart
keyless door locks,
dome light supervision,
maybe parking lights (depending on r/s)
http://www.the12volt.com/doorlocks/page3.asp#5w
use the 5 wire diagram listed here
yes you have to cut the factory wires at the drivers kick panel/
door connectors
i just put this one in a month ago
its made by dei (viper)
http://www.pythoncarsecurity.com/pro...?ProductID=619
Old Jan 2, 2010 | 12:51 PM
contractorben's Avatar
contractorben
what color wires do u tie into for the power locks?? Got everything wired but cant get this
Old Jan 2, 2010 | 01:02 PM
skostur79's Avatar
skostur79
http://64.85.6.129/extrainfo/diagram...BS%20UNITS.pdf
tie into the pink/violet and orange violet at the door jamb harness
not much room its accessed above the ebrake unit
i disconnected it from the door to more area to solder to
Old Jan 2, 2010 | 01:04 PM
BigRedRam95
How hard was it to wire it all? How hard was the remote start?
Old Jan 3, 2010 | 01:13 PM
contractorben
ok that makes more sense use the frist diagram correct? I need help on my door trigger and dome light supervison and remote start. My remote says door open I have the (-) door trigger input connected to the yellow (-) in the white conn. under driver kick panel. I disconnected the dome light relay becasuse i thought i did it wrong. Can u please go over this and the remote start wire up. This is how i did my remote start wire up (+) ignition 1 input/output to dark blue; (+) accesory output to blk/white; (+) starter output to (yellow going to truck); (+) starter input to (yellow going to key) (I cut this wire); there r more wires on the harness ??? I need help??
Old Jan 3, 2010 | 02:57 PM
clap's Avatar
clap
Look up bulldog security on the net. On there site they have a section that tells you what color wires you are looking for to tap into and also there location. Most of what you are looking for will be in the bundle of wire in the steering colum. Just be careful with the wire for the air bag ,even if you probe those wire can set it off. It will tell you what wire not to mess with also in the bulldog security site
Clap
Old Jan 3, 2010 | 04:15 PM
skostur79's Avatar
skostur79
you should have on 2 igntions blue , and blue/ black test them with a test light
to make sure you have the right ones ign on with key it should light up,
one accessory blk/orn
the viper has you cut the yellow start wire for starter interupt
just make sure the vipers(purple wire go to starter side of your cut)
http://64.85.6.121/diagrams/printpag...7261&MakeID=16
Old Jan 3, 2010 | 06:09 PM
contractorben
well do I need to put a relay on this on harness i used this diagram for my wire up may be it wont start due to the door trigger any insight there?? what did u use for ur dome light, and door trigger (what wire)
Old Jan 3, 2010 | 07:04 PM
skostur79's Avatar
skostur79
wont start will have nothing to do to door trigger
will the r/s power up but no starter engage ?
i used yellow at the door jamb , use relay for dome light
alarm module cant handle current of dome lights directly
