viper alarm wiring??
Old Jan 3, 2010 | 08:21 PM
  #21
BigRedRam95's Avatar
BigRedRam95
Originally Posted by skostur79
wont start will have nothing to do to door trigger
will the r/s power up but no starter engage ?
i used yellow at the door jamb , use relay for dome light
alarm module cant handle current of dome lights directly
What else do I need relays for when I install my alarm and what size? Thanks
Old Jan 4, 2010 | 09:07 PM
  #22
contractorben's Avatar
contractorben
yes u can hear the alarm make some noise but no starter engage, what did u use for the door trigger?? (the same yellow wire??) Big Red: I guess two for the locks, one for the dome light, I am wondeing about one for the starter, I have some type of on board relay if I need one for the starter how/can I use that??) This alarm is far harder than any thing I have wired on a car. Thanks
Old Jan 4, 2010 | 09:22 PM
  #23
BigRedRam95
Well for the relays I am thanking I need two for the dook lock/unlock, one for dome lights, one for the horn, one for the parking light flash. The alarm I got the 7900 has a relay with it for the starter I dont know how to use the factory onboard relay. I just wonder what amp relays I should get? I am thanking that I am going to have it installed for me.
Old Jan 5, 2010 | 06:33 PM
  #24
BigRedRam95
Bump.
Old Jan 5, 2010 | 07:56 PM
  #25
skostur79's Avatar
skostur79
ok the r/s turn on the dash light but no crank
1. check the (purple?) start wire from r/s with a test light
while remote starting it should light up
if its not check the hood shut down wire for being grounded
,brake input shuting it down , there might be one wire used to shut down
make sure thats not grounded
email me direct if needed
hey big red
dei make a neat door lock relay module 451m?
so youll only need one of them
your basic 20 amp relays will work ,
most alarm cant handle the current
they supply the ground so the relay energizes
Old Jan 7, 2010 | 01:20 PM
  #26
contractorben
do i need a relay for the starter??
Old Jan 7, 2010 | 02:46 PM
  #27
contractorben
I was just told that I need a bypass this because the truck has a key sense thing that knows when the key is nt in the truck. I have a black key is this true??
Old Jan 7, 2010 | 05:36 PM
  #28
skostur79's Avatar
skostur79
nope only gray large head keys"sentry" are transponder keys
no relays built into it ,
are you getting the voltage out on the purple when r/s it ?
Old Jan 11, 2010 | 05:47 PM
  #29
contractorben
well decided to have local alarm co. look at it, bad news remote start part of alarm is not working right, good news I not a complete dumb a. Sent alarm back today they are sending me a new one.
Old Jan 11, 2010 | 06:40 PM
  #30
skostur79's Avatar
skostur79
well keep us posted ,
that r/s isnt the easiest , even harder if its your first install
