Headlight switch and plug meltdown, need help
Old Dec 28, 2009 | 10:41 PM
Blesst0526's Avatar
Blesst0526
Default Headlight switch and plug meltdown, need help
While plowing I had a meltdown between headlight switch and plug. I have learned that this is a common issue, but I have added a new wrinkle all my own. I have replaced the switch and the plug and now the headlights work again , but now the marker lights do not work properly . They work only when the switch is halfway between the marker light location and the headlight location. When the switch is pulled out all the way to headlights, the marker lights go out. Anyone have any input, I would be much appreciative. Thanks for helping out the new guy.
Craig
Old Dec 29, 2009 | 12:25 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to the forums! You may want to ask this question over in the diesel section as well.
When you say you replaced the plug, I'm assuming you did some wiring. Are you sure you wired it (or whomever wired it) properly?
Old Dec 29, 2009 | 12:28 AM
Ram_It98's Avatar
Ram_It98
mine did the samething it turned out to be a blown fuse
Old Dec 29, 2009 | 12:46 AM
Blesst0526's Avatar
Blesst0526
Yes, I have double checked and triple checked that wires are connected where they are supposed to be, but stranger things have happened.
Do you remember which fuse was blown?
Old Dec 29, 2009 | 08:00 AM
halfamil's Avatar
halfamil
If they come on with the switch out halfway,it's not a fuse.It has to be the switch.The replacement switches are hit or miss China junk IMHO.
Old Dec 29, 2009 | 10:03 AM
Ram_It98's Avatar
Ram_It98
it was the gage cluster fuse not the illum..i went and bought a new switch thinkin it was that but it kept doing so i looked at all the fuses again and found out it was just blown fuse but i did keep the new switch in it lol
Old Dec 29, 2009 | 12:52 PM
Blesst0526's Avatar
Blesst0526
Thank you all for your input, turns out that the fuse was blown and the lights must be getting feedback through the switch when in the in between position.
