Tranny wont engage
Old Jan 1, 2010 | 04:12 PM
fatchance82's Avatar
fatchance82
Default Tranny wont engage
ive got a 2001 ram 1500 4x4 auto-trans. starts up fine, apply brake and shift into any gear R-N-D-D2-D1 and a fairly loud buzzing noise emits from the tranny. and it doesnt enage most the time. if does it seems pretty delayed. unsafe to drive right now. i need help bad. fluid levels are good and not burnt. only about 10k miles since fluid and filter replaced. no current engine codes.
Old Jan 1, 2010 | 04:52 PM
95RAM360's Avatar
95RAM360
how many miles? these have weak trannys and typically by 150K they need a rebuild....it sounds like your torque converter is shot...
Old Jan 1, 2010 | 05:18 PM
fatchance82
85,142 miles. how difficult is that to replace. or would it be safe to drive 10 miles to the shop in that condition without damaging anything else?
Old Jan 1, 2010 | 05:19 PM
Ram_It98's Avatar
Ram_It98
T.Q r easy to change but you have to drop the trans
Old Jan 1, 2010 | 05:33 PM
fatchance82
how much would a TC run me?
Old Jan 1, 2010 | 06:30 PM
fatchance82
...shameless bump...
Old Jan 1, 2010 | 06:34 PM
Ram_It98's Avatar
Ram_It98
im not really sure i dont drive auto i have always had a stick but i think my brother paid like 75-125$$ for his tc
Old Jan 1, 2010 | 06:41 PM
95RAM360's Avatar
95RAM360
you dont want to go cheap on the TC....maybe like 200-400 bucks.and yes you have to drop the trans. id let someone with a lift and proper jacks do it...these trannys are heavy, and you dont want it to drop/damage anything
do you do any towing?
Old Jan 1, 2010 | 06:47 PM
Ram_It98's Avatar
Ram_It98
you can get a tranny jack at harbor fraght for cheap the shop i worked at in KY had some and they worked great it has a chain to go around the trans to keep it stable and sometimes you can keep the crossmember on the trans
Old Jan 1, 2010 | 09:31 PM
fatchance82
hmm as fun as that sounds to tackle, and as much as i hate to i may have to take it to a shop. only thing ive done to my tranny is drop the pan and replace a few things behind the filter. able to do that laying under the truck. I need it for work. plus the shop is only 2 minutes away from work. may have to bit the bullet on this one. ill try to get it there monday so ill post back when i found something out. if im feeling froggy in the morning i may drop the pan and see if anything floating around in there. thx for help
