driveline vibration
Old Jan 2, 2010 | 10:19 PM
halfamil's Avatar
halfamil
Could be the installation of the tranny.The u-joints didn't go bad while the driveshaft was out of the truck unless the caps came off and were not replaced correctly with all the needle bearings.
Old Jan 2, 2010 | 10:29 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
well one of these days during this week i am going to replace the one u joint that has a little play in it and see where i stand after that....
Old Jan 2, 2010 | 10:45 PM
dhvaughan's Avatar
dhvaughan
while you have the driveshaft out, you might want to crank it and run it gently. see if the vibration comes out of the transmission/t-case, or if its smooth.
Old Jan 2, 2010 | 10:51 PM
xxxcowxboyxxx
i didnt think of doing that....but i think i will.
Old Jan 2, 2010 | 10:54 PM
xxxcowxboyxxx
when i am at highway speedss ( or any) and im on the throttle thats when it vibrates....but if i slip it into neutral even at the same speed and rev on it.....nothing...its smooth...only does it vibrate when there is torque on driveline
Old Jan 2, 2010 | 11:05 PM
halfamil's Avatar
halfamil
It's not the u-joints or driveshaft if that is the case.
Old Jan 2, 2010 | 11:08 PM
xxxcowxboyxxx
any ideas then???
Old Jan 3, 2010 | 01:35 AM
redheadhunter21's Avatar
redheadhunter21
Any noise associated with the vibration
Old Jan 3, 2010 | 09:13 AM
xxxcowxboyxxx
nope no nois at all.....the only noise i get is from my 4 wheel drive lever vibrating around
Old Mar 27, 2010 | 11:56 AM
countryrebel's Avatar
countryrebel
I am having the same problem with my 98. Did you find out what was causing the problem? I put on new wheels and tires and new u-joints and it still vibrates same as yours. I have a man trans.
