cheap lift?
Old 01-05-2010, 02:02 PM
011500Ram's Avatar
011500Ram
011500Ram is offline
Someone showed me a link to a thread he posted in. From what I read, he had the exact same suspension problem I did.
I love my spindles. They are Doetsch spindles, but I had them customized a bit. That way when I want to throw uniballs in them later when I do either arms or beams, I can. They are also pre-drilled to accept Dana 44 snouts. I also had the back reinforced with 1/2" plate.
With 3.5 inch spindles, the truck actually sat perfectly level. That's what 10 years of spring sag will do to you!
Old 01-05-2010, 02:05 PM
Gav1n8's Avatar
Gav1n8
Gav1n8 is offline
wasn't he banned?
Old 01-05-2010, 02:06 PM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
yes, he was banned......
my truck is dropped 2" in the rear and it still needs 2 more to be level
011500Ram's Avatar
011500Ram
That's what it says under his username. He had limit straps on his lower arms, no?
Old 01-05-2010, 02:09 PM
dakotas ram
yeah, and he had to grind somewhere
Old 01-05-2010, 02:11 PM
Gav1n8's Avatar
Gav1n8
Gav1n8 is offline
011500ram reminds me of him...
Old 01-05-2010, 02:17 PM
011500Ram's Avatar
011500Ram
I'm guessing he either ground the back of the factory spindles, or he ground where the end of the bump stop is set.
If either is the case, I wouldn't. Sure you will weasel another half inch out of the suspension, but that is an awful lot of trust to put into limit straps. Especially when they are going to sit nearly topped out all the time.
I'm sorry?
Old 01-05-2010, 02:22 PM
Gav1n8's Avatar
Gav1n8
Gav1n8 is offline
Apology accepted.
Old 01-05-2010, 02:34 PM
011500Ram's Avatar
011500Ram
hahaha
Old 01-05-2010, 02:37 PM
dakotas ram
yeah, you do remind me also, but thats a good thing cause i dont think either of yall are/were bad guys...theres a few instances where i stuck up for viper cause the 4x4 guys would jump all over 2wds and they didnt like it when he jumped back
Quick Reply: cheap lift?
