4x4 blues
Old Jan 5, 2010 | 06:24 PM
1994ram1500's Avatar
1994ram1500
Default 4x4 blues
okay guys i'm at a loss with my 94 1500. i am having 4wd issues. the truck will go into 4wd but periodically it kicks out, then kicks back in a split second later. this causes a the truck to jerk and is happening at the front axle. i replaced the vacuum switch to no avail, my mechanic hooked up a vacuum pump to the lines and actuator and confirmed that they all held good pressure. i do not know where to go from here? anybody have a similar problem? any suggestions to what may be going wrong?
thanks alot!
Old Jan 5, 2010 | 06:30 PM
Miami_Son's Avatar
Miami_Son
A search would have led you to some good threads on the subject. Start with "No X4" just like that with the quotes.
Old Jan 5, 2010 | 06:33 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
it may be a transfer case problem....not at the front axle.......just a thought
Old Jan 5, 2010 | 07:29 PM
1994ram1500
i did a search, but none of the threads i found answered my issue. i'm almsot positive it is coming from the axle because everytime it kicks out the 4x4 light blinks
Old Jan 5, 2010 | 09:57 PM
xxxcowxboyxxx
just bc your 4x4 light blinks doesnt mean it still cant be coming from the t-case.
Old Jan 5, 2010 | 11:40 PM
Keegan's Avatar
Keegan
I had all sorts of problems with my 4WD last winter. I took the vacuum actuator out, oiled it up really well, shot compressed air in each of the two vac ports to make sure it was working top notch. I Also changed my diff. fluid and put a new gasket in there, and checked over the vac lines running to the actuator. Now my 4WD kicks in and out with no problems at all. Before you could go down the road 1/2Km after taking it out of 4WD and the front axle was still engaged, but now, when you take it out, the light shuts off and the front axle is disengaged right away. It runs like brand new lol, only has 283,000Km lol.
Another thing you might want to check is the trans. mount if you have a 5spd ( I suppose auto too). Mine was so badly compressed and worn, it caused the front driveshaft to have alignment issues with the T-case, and getting in and out of 4WD was a real pain!
Old Jan 6, 2010 | 04:17 PM
1994ram1500
okay, i made a homemade posi-lock almost identical to this one: http://www.jeepforum.com/forum/f12/h...ite-up-595515/ and when i pull the cable, 4wd engages, however, the axle puts so much force on the fork that it kicks the cable back in, so much force that i have trouble holding onto it to keep it locked in. the coupler shouldnt be forced one way or another by anything but the fork, right? i've about had it with the thing, lol
Old Jan 6, 2010 | 04:45 PM
95RAM360's Avatar
95RAM360
when i first bought the truck i had 4x issues, and i st replacedhe diff fluid, and all vacuum lines, now engages/disengages perfectly
Old Jan 6, 2010 | 05:02 PM
1994ram1500
okay, it is on my agenda to change the fluid tomorrow, but it is so dang cold outside i dont know if i can get the old junk to flow. maybe a heat gun will do the trick.
