Ignition locked "Solution"
Old Jan 6, 2010 | 12:50 PM
frustratedram1500's Avatar
frustratedram1500
Default Ignition locked "Solution"
Did some more research on line and found out Chrysler ignitions of all kinds have this problem because the factory grease put into the ignition tumblers hardens when it gets old and won't let the tumblers fall back in place....(Also it was very cold last night)simple solution is to place key in ignition and tap on the key with a rubber mallet a few good times....PROBLEM SOLVED !!!! At least for now, I'm up and running !!!!!
Old Jan 6, 2010 | 01:16 PM
95RAM360's Avatar
95RAM360
good to know...
just for future ref. post this in the thread that you already started because
#1 they are going to merge it anyways and
#2 its good to post the solution in the original thread in case some people have the same problem they can look on your thread, and see begining to end....see what i mean?
Old Jan 6, 2010 | 03:50 PM
PurplDodge's Avatar
PurplDodge
What was the problem at hand?
