Help identifying part
Old Jan 6, 2010 | 01:46 PM
drlmerwin's Avatar
drlmerwin
Default Help identifying part
Hi everyone! I need information a 2001 Dodge Ram 1/2T PU 2wd 5.9L. I need to find out what this part is called that is located on the gas pedal, which seems to be connecting to either a cable or sensor. Yesterday, had an incident after replacing the thermostat. Took the truck for a test drive, punched the gas to check if the truck would warm up. Well, after that...the gas pedal popped out, but the truck still went full speed. I am not sure what connects from the gas pedal to the engine, but if someone who knows what they are doing can really help a lot. Thank you!
Old Jan 6, 2010 | 02:55 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site and it is called a throttle cable. I will move this thread to the second generation Ram section,
FF
Old Jan 6, 2010 | 03:11 PM
97black_ram's Avatar
97black_ram
+1 on throttle cable. Also check and see if it only popped out then you might be able to pop it back in...
Old Jan 6, 2010 | 03:33 PM
PurplDodge's Avatar
PurplDodge
Check the cable.
Old Jan 6, 2010 | 04:28 PM
Miami_Son's Avatar
Miami_Son
Please use more descriptive titles (I changed yours) so that other members with similar issues can find the thread in a search. Welcome to DF.
