heat not getting warm
Old Jan 13, 2010 | 09:28 PM
mr freeze's Avatar
mr freeze
Talking
I have the 180 tstat in my truck and this cold spell has taken a little heat away from my truck as well.Then again I havent checked anti freeze ratio since I owned the truck,lol.
Old Jan 13, 2010 | 10:32 PM
halfamil's Avatar
halfamil
I see you've been a member here since 2007. How long have you owned it ? Time to flush the system.50/50 is ok. I put just a bit more antifreeze/coolant than that. 1 gal. af/cool and 1 gal. distilled water then top it off with 1/2-3/4 gal. af/cool. Add a small amount of distilled water after you run it with the cap off(burp the air out). 20qts. max. if you drain the coolant from the engine.
