burning oil HELP
Old Jan 8, 2010 | 01:19 PM
97black_ram's Avatar
97black_ram
Originally Posted by 95RAM360
question.....when i first sart my truck in the morning i have thick white smoke for about 10 mins...this isnt bad is it? once warmed up theres no smoke atall, even when i punch it...
i just got worried cuz above stated white smoke is head gaskets
That's normal. its like when you breath outside and you see your hot breath in the cold air. Same principle with the truck, hot exhaust gases and cold air.
Old Jan 8, 2010 | 04:29 PM
redneck86's Avatar
redneck86
Originally Posted by 97black_ram
burning that much oil is bad Pull your plugs, see if any of them are coated in oil. Is the truck running rough? I doubt the head gaskets will fix the oil problem.
Do a compression test or leak down test on the cylinders to find out if your piston rings are good
truck only runs rough once im low on oil i keep refilling it to keep her going strong, lets just say worse comes to worse would it be better to just rebuild the engine block or just fix the 3 problems have mentioned it could be,
Old Jan 8, 2010 | 05:41 PM
Gav1n8's Avatar
Gav1n8
Considered finding a wrecked dodge at the salvage yard with however many miles? You can get a 360 around here with around 80,000 miles for about 6-700 bucks...
Old Jan 8, 2010 | 08:41 PM
97black_ram
Well were not sure what the exact problem is yet. Depends on how much money ur willing to put in the truck. Can fix those 3 problems then have another and the truck ends up nickel and diming you. Right now I'm sure buying oil like you are just to keep it going is getting expensive.
Old Jan 8, 2010 | 08:49 PM
dr. watson's Avatar
dr. watson
I had the same problem........check your back two spark plugs.....If they are oily, check the others......If this is the case it is probably the plenum gasket leaking. it is a pan that is poorly designed under the intake manifold. I thought it sounded terrible to do..... really wasn't that bad, just took me about 5 hours to do.....I take my time and clean things and try to do it right.....I found the post on here, about 1-1/2 years ago.the gasket for this and the intake cost about $25 they also make an upgrade kit for about $100....I went the cheap way....depends wether you are keeping the truck or not. My local dealer wanted $750 to do it.....it is simple. you should get new intake bolts also.....so another $10? check those plugs though.....talk to some people on here.... get more opinions.... fixed mine though!
