Wierd electrical issue
Old Jan 9, 2010 | 12:32 AM
CappinHoff's Avatar
CappinHoff
Default Wierd electrical issue
So it's gotten real real cold, -7 as the low and -1 as the hi. So I went to start my truck this morning and the ignition was hard to turn, but it started. However there was no blower, radio, turn signal, pwr windows and pwr locks. Also the brake and ABS lights came on. I checked all the fuses and they are all ok. So after letting it run I went and turned it off after it was warm and restarted it. Everything was working. Now 12 hours later I went to start it and all was fine.
Does anyone know what could have caused this?
Old Jan 9, 2010 | 12:41 AM
halfamil's Avatar
halfamil
It was the extreme cold.How long had it been shut down before you started it?
Old Jan 9, 2010 | 12:43 AM
CappinHoff's Avatar
CappinHoff
About 6 hours. I figured it was the cold, but I haven't had this issue before, and it's been this cold for 2 weeks.
Old Jan 9, 2010 | 01:00 AM
halfamil's Avatar
halfamil
Probably a small amount of moisture somewhere, when you shut it off, then, it quickly froze.
Old Jan 9, 2010 | 06:52 AM
95RAM360's Avatar
95RAM360
maybe your battery wasnt getting a strong enough connection
Old Jan 9, 2010 | 09:04 AM
heckman15's Avatar
heckman15
i had that happen a few days ago i bet ur wipers wouldnt work and u probably didnt have power to ur cigarette lighter either? but yeah its only done it the one time. i wouldnt worry about it. if something serious turns up in mine i'll let you know.
Old Jan 9, 2010 | 09:46 AM
CappinHoff's Avatar
CappinHoff
No cus it started right up with no issues.
Yep no wipers or cig lighter.
