Automatic to Manual Tranny Swap
Old Jan 9, 2010 | 04:54 PM
charleslardner's Avatar
charleslardner
Default Automatic to Manual Tranny Swap
I am considering swapping out my Automatic for a 5sp Manual Transmision. Is there anyone that has done this or know any usefull info I should know? I have a 96 Ram 1500 Club Cab, Short Bed, with a 5.2 V8.
Old Jan 9, 2010 | 04:55 PM
95RAM360's Avatar
95RAM360
since you have the 5.2 i believe it should bolt up but you'd need a new transfer case as well...
Old Jan 9, 2010 | 04:58 PM
charleslardner
I don't have a 4X4!
Old Jan 9, 2010 | 05:23 PM
RamSport97's Avatar
RamSport97
This is a pretty common topic and has been discussed many times, a quick search came up with a few threads on it.
https://dodgeforum.com/forum/2nd-gen...onversion.html
https://dodgeforum.com/forum/2nd-gen...eed-imput.html
Looks like you will need a new PCM, Gauge Cluster, clutch pedal and linkage assembly, cut hole in tranny hump, and possibly get a different drive shaft, because (IIRC) I believe the NV3500 manual tranny is a bit longer then the auto, or maybe it is the other way around. And I believe there is even more to it then that.
If this truck is your daily driver I honestly wouldn't do it.
Old Jan 9, 2010 | 05:31 PM
leahyhfarms's Avatar
leahyhfarms
You want to be careful what tranny you buy because when those 5 spd get to about 20000 miles give or take they start to give trouble with syncros and there is a nut inside that is prone to coming loose around thses miles too.
Old Jan 9, 2010 | 06:23 PM
charleslardner
I think you all just answered my question and changed my mind about this. I think I will just get the Automatic rebuilt!
Old Jan 9, 2010 | 07:19 PM
95RAM360's Avatar
95RAM360
sorry didnt relize 4x2......
and the auto would be a better go...i believe you'll loose much acceleration with the 5 speed....and IMO its just not worth it....
and the bolt is in the fifth gear i think, a jam nut...it falls out, gets in the gears, and grind them...well destroying the tranny
Old Jan 9, 2010 | 08:22 PM
Gord.'s Avatar
Gord.
Funny, my 95' with the NV3500 has 430,000 kms (267,000 mi) has almost no issue with the syncros. Every now and then it will be stiff into first, but thats all. The fifth gear nut is something I have never heard of on the NV3500, but is a common issue on the NV4500.
From everything I have read (on this forum and a few others) the NV3500 is much more reliable than the auto, and by design automatics take more power to run and will therefore have worse accelation than a manual.
Gord.
Old Jan 9, 2010 | 08:31 PM
olyelr's Avatar
olyelr
Gord.
I agree 100%. Very well said.
Old Jan 9, 2010 | 09:47 PM
95RAM360's Avatar
95RAM360
my bad....i thought he was going with the 4500...but now i relize thats for the cummins and heavier rams lol
.....i really need to pay more attention
