introduction..look inside
Old Jan 10, 2010 | 04:00 PM
wake's Avatar
wake
Default introduction..look inside
hey folks..the names wake..or you can call me by my first name..which is lucas..
ive been apart of a few clubs in my time..figured id get around to signing up over here..now in case you havent seen my sig pic yet..
i have a 1995 dodge ram 1500 4x4 reg cab long bed..pics will come later in this thread its pretty unique...considering..ive done a few things here or there but had to park it until i can find another job..cause the ball joint is almost completely out..and i need new pads,rotors,calipers really bad..
i bought this truck as is from my landlord who used it as a plow truck..its only got 101K on it
i picked it up for 1500 dollars cash..
anything else you wanna know just ask..
now on with the pics .
reverse lights
brake,license plate lights
Old Jan 10, 2010 | 04:09 PM
95RAM360's Avatar
95RAM360
Welcome to the Forums!
good lookin truck.
FYI do a search on the plenum gasket. EVERY 2nd gen 1500 will have this issue.
Also these trannys typically need a rebuild by 125K-145K. That truck was used for plowing, so the tranny might not have that much life left...within 20K id say.
All in all, for the price thats a hell of a deal for the condition/miles. Def. a good buy.
Old Jan 10, 2010 | 04:12 PM
dodgeram07's Avatar
dodgeram07
welcome to the RH trans club..lol
good luck with the job hunt,,,, was kind of cb your running?
Old Jan 10, 2010 | 04:16 PM
wake's Avatar
wake
thanks..ya know i knew i was forgetting something in my OP
new parts within the last 10K miles
upper and lower intake manifold gaskets
plugs and wires
t-stat
water pump
timing chain
air filter
coolant change
trans fluid/filter and shift kit
u joints on front drive shaft
new spindle gears on front axle
transfer case fluid change
i know theres a few things that im missing but..this thing has been maintained religiously
i know both previous owners..and they have kept a good eye on the trans changing the fluid and filter ever 8-10K miles
oil every 3K miles
good eye my man i was wondering if anyone was gonna spot the antenna..i was running a cobra night walker but had to sell it cause i needed to the money
Old Jan 10, 2010 | 04:18 PM
95RAM360's Avatar
95RAM360
nuff said...Hell of a deal
Old Jan 10, 2010 | 04:21 PM
wake's Avatar
wake
btw of the top of my head without looking at my build sheet that i recieved from dodge the other day
9.25 rear diff
3.55 front diff
195 mm front axle
3.55 or 3.65 tranny gears
231 HD transfer case
6 way power seat,which isnt in the truck now..someone took it out UGH
heavy duty springs and shocks with half ton leafs vs heavy duty leafs DOH
Old Jan 10, 2010 | 04:22 PM
Hammer Down's Avatar
Hammer Down
Welcome to the forum! We have some pretty knowlegeable people around here. We're pretty friendly too... that is as long as you don't commit the sin of asking before searching for an answer. Sereiously, there is a lot of information to be had from prior discussions that you can find with the search feature.
That's a nice looking truck you have! Is that s sub box I see between the seats?
Old Jan 10, 2010 | 04:26 PM
wake's Avatar
wake
yes sir that is a sub box and amp where the middle bucket is supposed to be
2 mtx 10's road thunder series quad bandpass circa 1997
still slam damn good too
EDIT: i knew i was forgetting something..its got the 33 gallon tank vs the 25 gallon
Old Jan 10, 2010 | 04:31 PM
Hammer Down
I'm tempted to do something similar, but I would love to find a way to mount a sub and keep seat #6 (It comes in handy now and again). I bet that hits hard with two 10's in that little cab!
Old Jan 10, 2010 | 04:35 PM
wake's Avatar
wake
yes it does man..and im going to eventually put another 12 in there..
i have a few ideas im tossin around..ill letcha know if i come up with anything via PM
