Help - truck won't go into reverse
Old Jan 14, 2010 | 08:40 AM
wcox06's Avatar
wcox06
Default Help - truck won't go into reverse
MY 1999 DODGE RAM WILL NOT GO INTO REVERSE OR PARK FROM DRIVE. It runs just fine, will shift everywhere but stops at reverse and it feels like something is blocking it. I tried driving and switching gears - would not work. It's not making any new noises, grinding or such. Need help or advice please.
Old Jan 14, 2010 | 08:44 AM
halfamil's Avatar
halfamil
Are you saying the shift lever won't move up to R or Park ?
Old Jan 14, 2010 | 09:55 AM
clipper77's Avatar
clipper77
Thats what i sounds like hes trying to say.
Old Jan 14, 2010 | 12:10 PM
97black_ram's Avatar
97black_ram
Go under the truck and check your shifter linkages...
Old Jan 14, 2010 | 01:27 PM
rideordie's Avatar
rideordie
+1
Next time, please try to use the search button to find an answer before posting.. It helps keep the forums clean, and you can even find answers faster a lot of the time.
NO REVERSE (D RANGES OK)
1. Gearshift Linkage/Cable Mis-adjusted/Damaged. 1. Repair or replace linkage parts as needed.
2. Park Sprag Sticking. 2. Replace overdrive annulus gear.
3. Rear Band Mis-adjusted/Worn. 3. Adjust band; replace.
4. Valve Body Malfunction. 4. Remove and service valve body. Replace valve body if any valves or valve bores are worn or damaged.
5. Rear Servo Malfunction. 5. Remove and disassemble transmission. Replace worn/damaged servo parts as necessary.
6. Direct Clutch in Overdrive Worn. 6. Disassemble overdrive. Replace worn or damaged parts.
7. Front Clutch Burnt. 7. Remove and disassemble transmission. Replace worn, damaged clutch parts as required.
https://dodgeforum.com/forum/1702727-post1.html
Old Apr 12, 2013 | 01:45 AM
jammers0923's Avatar
jammers0923
Default Same Problem
I'm having the same problem with my 1998 Dodge Ram... Did you figure out what it was by chance?
Old Apr 12, 2013 | 09:27 AM
Drop the pan, see what you find.
Old Apr 12, 2013 | 02:34 PM
gdstock's Avatar
gdstock
Did you see the post right before yours (dated 1020...)? Try #1 first.
...and then this is steps 2 - 7.
Old Nov 14, 2020 | 11:47 PM
Creyo Trra's Avatar
Creyo Trra
Band anchor and accumulator
Common band anchor and accumulator
Old Mar 23, 2021 | 12:40 AM
Valiri r's Avatar
Valiri r
My 2001 dodge ram my reverse stopped working it just sounds like im giving it gas when its in neutral but its in reverse what should i do to fix it? Also my kickdown cable is broke could that be the problem?
