Starts, runs 3 min, stalls, sits 30 min, same problem
Old Jan 15, 2010 | 12:03 PM
otisotis's Avatar
otisotis
Unhappy Starts, runs 3 min, stalls, sits 30 min, same problem
My 96 Ram 1500, 2wd 3.9l 6cyl. Starts fine, works for 2-3 minutes, loses power, stalls, won't start for 30 min, will run again for the same thing. No fault codes. Tried new o2 sensors, filled with new gasoline, can hear fuel pump running... thinking that a clogged fuel filter wont let it run full force for that long... leaving it sitting at idle gives same result...
The problem is so consistant, not sure what to do???
Old Jan 15, 2010 | 12:06 PM
95RAM360's Avatar
95RAM360
could be a clogged CAT....when you change the upstream 02 sensor did it "relieve pressure" when taken out? thats a sign of a clogged CAT.
The fuel pump may be kicking out...
We had a 2500 5.9L in our shop, and itwas doing the same thing as your, and it turned out t be fuel pump/ fuel pump relay
Old Jan 15, 2010 | 12:31 PM
pcfixerpro's Avatar
pcfixerpro
Do yourself a favor and see if you are getting spark after the engine stalls and won't restart. Pull a wire off a spark plug, toss in an extra plug into the wire. put the plug close to the engine block and have a friend crank to see if you can see the spark jumping. (haha be sure to hold the wire boot, and a pair of gloves wouldn't hurt either) By doing the above test, you are ruling out the ignition coil.
If you have spark, keep looking for a solution
If you do not have spark, replace ignition coil and report back.
Old Jan 15, 2010 | 12:32 PM
otisotis's Avatar
otisotis
Cat replaced bout a year ago (3rd one it has been a prob on this truck indeed) hope it shud still be good, affraid ur right about the fuel pump / relay just really hoped I didn't have to drop the tank...
Old Jan 15, 2010 | 12:34 PM
otisotis's Avatar
otisotis
k will do spark test... holding open plug between my teeth will make for great youtube vid...
Old Jan 15, 2010 | 12:46 PM
95RAM360's Avatar
95RAM360
^YES thats the proper way to do it.....
and you best bet would be the spark test first, then drop the tank.
Old Jan 15, 2010 | 12:51 PM
otisotis's Avatar
otisotis
Got spark (and clean teeth at the same time)
Old Jan 15, 2010 | 12:59 PM
95RAM360's Avatar
95RAM360
try replaced the fuel pump relay with somethin else under the hood. its a big black fuse. switch it with the other black ones and see if it happens again...if so, its time to drop the tank...this will eliminate the relay.
Old Jan 15, 2010 | 01:02 PM
pcfixerpro's Avatar
pcfixerpro
Hahaha nice. I have had coils heat up before and then quit working. Then when it cools down it will work for a while. In fact, my dads car suffers from heat soak on the starter solenoid which does the same thing... let it cool down then the solenoid would work again (chevys... :/) Anyway back to your problem. Before you go dropping the tank, you can check for fuel pressure by using the shrader valve on the drivers side fuel rail. You can get a gauge to check the pressure or you can simply check to see that fuel is getting there by pushing down on the pin (watch your eyes).
Old Jan 15, 2010 | 01:16 PM
95RAM360's Avatar
95RAM360
+1
and gas in your eyes doesnt feel good TRUST ME lol...ive had it happen when replacing a fuel tank, and it felt like someone was cooking my eye.
