Audio System relaying Noise?
Old Jan 18, 2010 | 09:09 AM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by 95RAM360
thanks for the info...i doubt its the amp itself due to the fact that it still pounds the same as it did, and i just bought it 5 months ago. theres no problem with the audio it works the same just has the added noise underneath.
There is circuitry built into the the HU (sometimes the noise filter is an external black blox on the power wire of the HU) and amp for noise isolation....this can sometimes fail...it can be bad and everything else could still work great...unless its done it since the install my guess is either something failed or one of your grounds is failing...or perhaps you have a damaged plug wire?
Old Jan 18, 2010 | 09:18 AM
95RAM360's Avatar
95RAM360
as in spark plug wire? no i have new msd 8.5 mm's
it could be the headunit since i got that 5 years ago.
Old Jan 18, 2010 | 04:29 PM
Augiedoggy's Avatar
Augiedoggy
yeah I meant plug wire...they are #1 source of radio interference...
I would still double check all your grounds....some rca cables even had an additional ground wire at each end to help shield against this...I used them in my jeep.
Old Jan 19, 2010 | 09:29 AM
Metal King 8989's Avatar
Metal King 8989
I did'nt read through all the responses here so i dont know if this was stated yet, alternator whine.... your rca cable is to close to your power cable.
