Replacing wheel bearing............
Old Jan 20, 2010 | 11:49 AM
  #51
95RAM360's Avatar
95RAM360
you'd be surprised...i have the old one out, i just havent gotten a new one to put in lol.
and the way these are set up you have to take out the radiator fans, idler pulley brackets, a/c condensor, andwe have snow on the ground, and i had to lay underneath to pull it out...it sucked
Old Jan 20, 2010 | 02:49 PM
  #52
95RAM360's Avatar
95RAM360
ok it time...im going to attempt this...
Sheriff i got the crc freezeoff, hopefully that will make it loose enought to crack it with my 1/2 drive.
wish me luck...
Old Jan 20, 2010 | 04:13 PM
  #53
95RAM360's Avatar
95RAM360
WTF!!!!!!!!!!!!!!!
ok im down to the hub nut, and the ***** f*cka will not budge. ive put heat to it, and nothing. ive been putting crc freezeoff through out the day, and before i started, still nothing.
tried heating it, and while it was hot, sprayed the freezeoff, and let it set, tried again, and nothing, not the slightest movement. im jumping n my breaker bar like a trampoline the b!tch wont budge
Old Jan 20, 2010 | 04:17 PM
  #54
yakkier's Avatar
yakkier
Use a pipe then, leverage is your friend.
Call me stupid but r u sure you're turning it the right way ? just a thought sometimes i get confused too
Old Jan 20, 2010 | 04:20 PM
  #55
95RAM360's Avatar
95RAM360
ive tried both ways and nothing
Old Jan 20, 2010 | 04:22 PM
  #56
yakkier's Avatar
yakkier
Sledge hammer and beat the **** outta the pipe, instead of constant pressure usually the back to back wacks with the sledge will break it loose
Old Jan 20, 2010 | 04:27 PM
  #57
merc225hp's Avatar
merc225hp
If you can't get it try this, Pull the hub and axle as 1 peace, get a bud to drive you to a shop with air tools and have them run the nut off for you. Just an idea.
Old Jan 20, 2010 | 05:43 PM
  #58
VEETEN's Avatar
VEETEN
As many have said leverage....
I used a 3/4" drive and a 4 foot piece of 1 1/4" galvanized pipe from Lowes.
left the wheel on and didn't have the jack under it till I got the nut to start moving.
Check the threads trough the castleated nut to see what way it needs to turn, I think it was Sheriff mentioned a way (if you're not familiar with left and right hand threads)
I think you're 1/2" breaker bar is gonna break.... if its not budging it
Old Jan 20, 2010 | 06:14 PM
  #59
cheshirer1's Avatar
cheshirer1
did my passenger side last summer. Took 3 days, 4 mechanic friends, 2 floor jacks, 3 cans of penitraiting oil, 100 miles of driving to find parts in my sisters grand Cherokee, a torch, a carton of cigarettes, it was dark and I was wearing sun glasses. (had to throw in the blues brothers)
2 of the mechanics said they usually see them at the shop towed in and the hub in pieces and that makes it easier for them. I agree that with kids, you cannot wait for that to happen.
It's going to be real tough to get it off. Gonna need alot of heat, penitraiting oil, hammers or impact gun to vibrate it. Good luck and you will get it off eventually. Make sure you have water or an extinguisher when you heat it. The oil can start to burn.
Old Jan 20, 2010 | 06:28 PM
  #60
95RAM360's Avatar
95RAM360
ok after jumping on my 1/2 in breaker, she snapped.....go figure.
thank god i still have my 1/2 in torque wrench so i could get my wheel back on.
went to sears and got a 20in. 3/4 in breaker bar and got 2feet of some heavy duty piping for leverage (65 bucks...god damn)
hopefully this will be enough to budge it, and now just my luck it started snowing...wtf
also according to my haynes repair manual, it said the DRIVERS side was reverse threaded...said nothing about the pass. side (which is the one im doing)
