Brake Problems
Old Jan 19, 2010 | 12:15 PM
1969 cj-5's Avatar
1969 cj-5
Default Brake Problems
Tried to search to see if ti was covered yet and no luck so here goes.
The brakes on my '01 are a might tetchy in the mornings for the first little bit. The rears lock up at the slightest touch to the pedal. Was wondering if there is a proportioning valve or somthing of the like that you all might know of that is causing this.
Old Jan 19, 2010 | 01:21 PM
charlie1935's Avatar
charlie1935
My 96 does the same thing, especially in damp or high humidity weather.
Still have original linings on the rear and no fluid leaks.
When I get new shoes I'll put premium ones on and see if that helps.
Old Jan 19, 2010 | 01:54 PM
merc225hp's Avatar
merc225hp
Yep I had the same thing with my 96, I had to replace the RWAL C/U under the master cyld. In my case it is a 1996 model year part and a dealer only part. Are you ready for this $700+ tax for a rebuilt from dealer or $1400+tax new from dealer, not installed. It only comes as a kit including master cyld, RWAL c/u and other parts. As I don't like using rebuilt or used parts I went with the new, After the install no more problems. I hope that you can find more options for new parts down in the US. Before I did the RWAL c/u I replaced every thing in the rear diff for parts IE drums, shoes, wheel cyld, springs, RWAL speed sensor, e brake cables.
Old Jan 19, 2010 | 02:47 PM
1969 cj-5's Avatar
1969 cj-5
What is an RWAL C/U?
Old Jan 19, 2010 | 03:21 PM
merc225hp's Avatar
merc225hp
It is (rear wheel anti lock control unit), it is found under the master brake cyld it is what used to be called the proportional valve. As your truck is 5 years newer than mine it might be (all wheel anti lock control unit).
Old Jan 19, 2010 | 03:30 PM
95RAM360's Avatar
95RAM360
i had the same problem, but since i fried my abs sensor and lost the abs it hasnt done it.
Old Jan 19, 2010 | 04:48 PM
merc225hp's Avatar
merc225hp
Ok so I did a quick check to make sure that I am using the rite name for that part, On my receipt it's called rwal c/u in the Haynes bible it is referred to as the rwal valve. If you have a Haynes book it's on page 9-22 figure 14-9 what you see in the figure is what you get from the dealer.
